B2630VSB3030
/ B2630VSB3030 #1
2630
I have the b2630 and can not help to wonder what the additional 4hp on the b3030 is like. I use my machine for fel work and backhoe work. Does the additional hp help the machine lift and dig better? Thanks in advance for any feedback.
/ B2630VSB3030 #2
Do you ever feel that the tractor is underpowered? Does it lug down? If not then you don't need more power. I have a B3030 and have always thought it had power to spare. I am sure I could do anything I want to with a few HP less.
/ B2630VSB3030
If I were to push into a pile in medium range. It may slightly bog down. Put her in low range and there is no bog at all. If anything you may get a little wheel spin.
/ B2630VSB3030 #4
Your power comments sound just like the statements that I have heard from B27-2910 owners. The extra 23 Cu. In and 3.5 PTO HP. Probably will not be noticed until a attachment like a 60" Rotary Cutter was hooked up to PTO. Even then you would need to have both models tractor on site to see difference. The $1500 savings between the 2 models may be well worth it. Unless a owner needed the extra PTO HP.
/ B2630VSB3030
Thanks alot for the input. So far the 2630 has exceeded my expectations. I feel that I have made the perfect choice. But I could not help but wonder about the additional ponys in the b3030. Thanks again!!
/ B2630VSB3030 #6
</font><font color="blue" class="small">( Thanks alot for the input. So far the 2630 has exceeded my expectations. I feel that I have made the perfect choice. But I could not help but wonder about the additional ponys in the b3030. Thanks again!!
)</font>
I didnt look at the additional ponys that much..I looked at the greater torque. I went ahead and sprang for the B3030 because it was only setting me back another $1000..and figures IF...IF I ever needed it..I had it...but admit I probably never will need it.
Except for road tavel I seldom run the engine over 2000 RPM..and its max power is at 2400 RPM...
/ B2630VSB3030 #7
I'm with ronjhall on this, you would be most apt to notice the power difference at the pto, i have put a whopping 7 hours on my 3030 mostly fertilizing & listening to C S N & Y on the cd, boy it gets warm in that cab, i had to turn on the ac. /forums/images/graemlins/grin.gif
MONOSEM NG+4 - 4R36" TWIN ROW VACUUM PLANTERS (A64276)
MONOSEM NG+4 -...
1990 FRUEHAUF 53' DRY VAN TRAILER (A64280)
1990 FRUEHAUF 53'...
SKID STEER AUGER ATTACHMENT (A62613)
SKID STEER AUGER...
SPIN SPREADER (A64280)
2022 Bautista Welding and Custom 40ft. 10 Ton T/A Gooseneck Flatbed Trailer (A61573)
2022 Bautista...
2016 Dodge Charger Sedan (A61574)
2016 Dodge Charger...
