B2630 Tire Leak
/ B2630 Tire Leak #1
brownsl
OH
I have a B2630 with filled rear tires. I noticed the other day that one of the rear tires was leaking a small amount of liquid by the rim and the tire was low. I wonder if it is leaking because the tire got low and the bead broke. If so, can I just inflate with air or will that not work once the bead is broke. I am hoping I can do that as opposed to taking the tire off and taking it in to get fixed. Also, if I inflate with air I assume the valve needs to be at the top?
/ B2630 Tire Leak #2
Yes, put the valve at the top and then add some air. If the leak stops and the tire stays up you are gtg. If it still leaks you have problem. Good luck.
/ B2630 Tire Leak #3
I would also recommend that you check the tightness of the valve core while you are at it. One of my filled tires was leaking and it was the core inside the valve stem.
/ B2630 Tire Leak #4
The problem you are going to have is the rim will rust at the bead now. Tires should never be filled without tubes. Unless of course you have a non corrosive inside then its not a big deal.
/ B2630 Tire Leak #5
Even with tubes over time the Valve stem will leak and the wheels will rust.
/ B2630 Tire Leak #6
Was at a tractor shop when a customer brought in this tire with a small leak.
Other picture was the inside.
/ B2630 Tire Leak #7
Perfect example of why I hate calcium chloride. I will choose cast every time in spite of the cost.
1996 International 4700 (A64127)
1996 International...
15ft. Hay Rack (A65640)
15ft. Hay Rack...
NEW ATA-EPC40 Plasma Cutter (A62679)
NEW ATA-EPC40...
2020 INTERNATIONAL LT625 SLEEPER (A59910)
2020 INTERNATIONAL...
Volvo VNL (A63689)
Volvo VNL (A63689)
Wagon Wheel Rocking Chair (A65583)
Wagon Wheel...
