B2630 Front Axle Fluid Capacity
   / B2630 Front Axle Fluid Capacity #1
davatk
Flint Hill, Virginia
Kubota B2630
Anyone know how much fluid the front axel on a B2630 holds ? I am gonna change it and re-fill with some 80W90 but can't find the capacity anywhere in the manual. :confused:
   / B2630 Front Axle Fluid Capacity #2
Per Kubota.com
Fuel 8.1 Gal.
Cooling 4.7 Qts
Crankcase 3.2Q/3L
Transmission 15.8Q/15L
Hydraulic The oil used to lubricate the transmission is also used as hydraulic fluid.
Axle 5 Qts.
Per Kubota.com
Fuel 8.1 Gal.
Cooling 4.7 Qts
Crankcase 3.2Q/3L
Axle 5 Qts.
Thanks Tyler. :thumbsup: I've gotta ask you - where did you find that info on Kubotas website ? I've searched it high and low and can't seem to find it ...:confused:
   / B2630 Front Axle Fluid Capacity #4
Have you considered 75w-90 synthetic? About the same price, and superior properties. Just a thought.
   / B2630 Front Axle Fluid Capacity #5
Kuboto.com
Click on Parts
In quick reference section on the left side, add your info
Click Search
Information was under the Fuel Tab
Kuboto.com
Click on Parts
Click Search
Thanks Tyler. Amazing - not sure how I missed that :eek:, but it is a little wierd for them to put it under "fuel".
   / B2630 Front Axle Fluid Capacity #7
I thought the same thing.
2010 CATERPILLAR 320DL RR EXCAVATOR (A60429)
2010 CATERPILLAR...
2021 CATERPILLAR D5 LGP HIGH TRACK CRAWLER DOZER (A52709)
2021 CATERPILLAR...
Kubota B2301 (A53317)
2004 VE ENTERPRISES 500BBL FRAC TANK (A58214)
2004 VE...
2012 KOMATSU PC360LC-10 EXCAVATOR (A60429)
2012 KOMATSU...
2022 John Deere 1023E MFWD Compact Utility Tractor with 120R Front Loader (A56438)
2022 John Deere...
