B2630 Front Axle Fluid Capacity
   / B2630 Front Axle Fluid Capacity #1
davatk
Flint Hill, Virginia
Kubota B2630
Anyone know how much fluid the front axel on a B2630 holds ? I am gonna change it and re-fill with some 80W90 but can't find the capacity anywhere in the manual. :confused:
   / B2630 Front Axle Fluid Capacity #2
Per Kubota.com
Fuel 8.1 Gal.
Cooling 4.7 Qts
Crankcase 3.2Q/3L
Transmission 15.8Q/15L
Hydraulic The oil used to lubricate the transmission is also used as hydraulic fluid.
Axle 5 Qts.
Per Kubota.com
Fuel 8.1 Gal.
Cooling 4.7 Qts
Crankcase 3.2Q/3L
Axle 5 Qts.
Thanks Tyler. :thumbsup: I've gotta ask you - where did you find that info on Kubotas website ? I've searched it high and low and can't seem to find it ...:confused:
   / B2630 Front Axle Fluid Capacity #4
Have you considered 75w-90 synthetic? About the same price, and superior properties. Just a thought.
   / B2630 Front Axle Fluid Capacity #5
Kuboto.com
Click on Parts
In quick reference section on the left side, add your info
Click Search
Information was under the Fuel Tab
Kuboto.com
Click on Parts
Click Search
Thanks Tyler. Amazing - not sure how I missed that :eek:, but it is a little wierd for them to put it under "fuel".
   / B2630 Front Axle Fluid Capacity #7
I thought the same thing.
UNUSED FUTURE FT-RP72 - 72" HYD ROCK CRUSHER (A52706)
UNUSED FUTURE...
TANK MANIFOLD (A58214)
2016 Toro Groundsmaster 4500-D 4WD Commercial Rotary Mower (A59228)
2016 Toro...
2017 Ford F-550 Bucket Truck - Power Stroke Diesel, ETI 40 Boom, 45 ft Working Height (A56438)
2017 Ford F-550...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
