b2620 MMM
/ b2620 MMM #1
lawn_master
I have a 2620 with a mmm. I want to use the rear PTO while the mower is attached. How do I lock the MMM in place so when I put the rear PTO up and down the mmm does not move? Can this be done and how? Thanks in advance
/ b2620 MMM #2
Set the height dial to "top". If that doesn't work, you can pin it up (if the holes line up for ya).
/ b2620 MMM #4
I would reccommend putting the pins in the front as well. They are a little tricky to get in and out. They should have come with the mower and are usually stored in the back brackets of the MMM.
2023 FREIGHTLINER M2 4X2 24FT SLEEPER BOX TRUCK (A59906)
2023 FREIGHTLINER...
2011 Open Range 424RLS 42ft. 5th Wheel T/A Travel Trailer (A59231)
2011 Open Range...
2001 International 4000 DT 466E (A60462)
2001 International...
2020 Bobcat E35 (A60462)
2020 Bobcat E35...
2016 FORD F550 CREW CAB SERVICE TRUCK (A59905)
2016 FORD F550...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
