B2620 has arrived...
   / B2620 has arrived...
Well, I've been using the B2620 around the place, and really like it so far. As you can see in the photos, bigger isn't always better. It seems to have enough power for the things I need to do, and enough stability, and clearance to get where I need to do them. The low hood height makes refueling a snap. I have moved the loader lock into the locked position a couple of times when operating sitting sideways to better control rear operations. It is very close to the rear hydro pedal. The loader is plenty strong for this size tractor, and will lift at least one rear (loaded) tire even with the bush hog mounted. Loader control is very smooth, and I have no trouble getting a full bucket of crusher run gravel every time.
Yes, I got pretty wet before I finished playing this morning. It will be too wet to work in my woods for a while now. Guess I'll have to put the chipper back on, and do some trimming along my road frontage, and field edges........ OH DARN! :D :D :D
Couple more pics for you guys on the edge.... :)
   / B2620 has arrived... #33
Hi Chuck,
It's been pretty wet here, too.
Sunday I was out working in the rain and came close to getting stuck a couple times. Interesting how slippery mud and rocks can be... :rolleyes:
I finally got my little old chipper up and running a couple days ago, and had a blast taking care of some piles that I had scattered around.
Now the forecast for the next couple of days looks like it will provide a good opportunity for me to break out the grease gun, since I won't be doing much outside until things dry up a bit. :(
Jay
Glad you got the chipper runing Jay! They sure are nice to have, and make short work of all the trimmings that come with having some land. I've got about 10 hours on my tractor now, so I need to do the grease thing, check the front axle lube level, etc. I had to put a couple of new grease fittings on my RC since the ones that came on it were really painted closed. I couldn't quite get five gallons of diesel in this morning when I fueled up, so I'm pretty happy about that too.
2019 KENWORTH T680 TANDEM AXLE SLEEPER (A51222)
2019 KENWORTH T680...
2022 BOBCAT T595 SKID STEER (A51242)
2022 BOBCAT T595...
DYNAPAC CA152PD PADFOOT ROLLER (A51242)
DYNAPAC CA152PD...
2015 Ford Explorer AWD SUV (A48082)
2015 Ford Explorer...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
