B2601 Weight?
/ B2601 Weight? #1
Indian MC
Southeast, NH
Kubota B2601
Hey everyone.
Off hand, does anyone know what the weight of a B2601 with LA434 FEL and BH70 BH attached? Will be shopping for a trailer soon.
Thank you!
/ B2601 Weight? #3
Google is your friend, try it.
1632 for the machine
559 for the bare FEL boom
~200 for a bucket
Can't find the BH, I'm sure you can figure it out, the above took me 90 seconds.
/ B2601 Weight? #4
The power unit weights about 1600 pounds, not sure about a BH70, but the BH77 is about 850 pounds, and a loader might be about the same depending on what you install in your tractor. If you load the tires it will add more, carrying extra implements, etc. You'd have to weight it, but a rough guess would put you around 3200-3500 lbs erring on the high side. If you went with a 7000 lbs trailer you would have plenty of extra capacity for anything extra you want to carry with you, keeping in mind you have to subtract the weight of the trailer from its payload.
/ B2601 Weight? #5
Tractor alone weighs 1632. Can't find any specs on the weight of an LA434 or BH70 but would guess each to be under 850 lbs. Total if each was 850 would be 3332 lbs. That could easily fit and be hauled on any dual axle 18' 7K landscape or car trailer.
/ B2601 Weight? #6
  • LA 434 Kubota Front Loader Operator's Manual-2.pdf
/ B2601 Weight? #7
Wow, that is a light tractor, considering that the BX25 ways 1587 pounds.
/ B2601 Weight? #9
all those book numbers will be low. They are generally shipping weights with Ag tires. You will need a 7000lb trailer, 16-18 foot.
/ B2601 Weight? #11
The bx25 includes the subframes weight so a couple hundred pounds.
Filled tires will spread the weight difference quickly between the B and BX.
The BH70 on the B2601 should be about 6-700, I didn't look it up on the 2601 but the b2620 had a listed max weight around 600 for a BH iirc.
Less then 850 lbs for loader with bucket and qa.
3500lbs is a safe guess on a tlb with loaded tires.
2005 FORD TAURUS CAR (A66091)
2005 FORD TAURUS...
PALLET OF CUT-OFF VALVES (A68842)
PALLET OF CUT-OFF...
WELDING TABLE WITH VISE (A68842)
WELDING TABLE WITH...
2018 GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A68842)
2018 GENERAC...
2016 CATERPILLAR TL1055D TELESCOPIC FORKLIFT (A64279)
2016 CATERPILLAR...
2011 HUTCHISON CRUDE TRAILER (A67714)
2011 HUTCHISON...
