B26 has a hydraulic oil leak
   / B26 has a hydraulic oil leak #1
GeneD14
Tennessee
Kubota B26 TLB, Allis Chalmers D17 series IV, Kubota ZG-23 Mower, Kubota ZD 1211, Kawasaki Mule 610, Stihl 361, Stihl 045 AV Super, and a Stihl 660 Ported and tuned
I have a 2013 B26 with 512 hours on it. It drips about a spoon full of hydraulic oil per day. I can稚 tell exactly the source, but it appears to be running down the large square oil reservoir underneath.
I致e looked around the filters and the square oil reservoir and I didn稚 see anything obvious.
Anyone have experience with a B26 oil leak?
Any ideas where I should check next?
Thanks
   / B26 has a hydraulic oil leak #2
Buy a couple of cans of cheap engine degreaser at WalMart. Clean all of the oil away with degreaser and soap & water, then you'll be able to see where it's leaking.
   / B26 has a hydraulic oil leak #3
Then after it dries...roll it in flower and look for a wet spot...:D
sorry could not resist...!
seriously though...it seems if it was on a pressure line there would be more oil so the obvious things to check are the return lines and where they connect to the tank...
Good ideas.
I will try narrowing the leak down this weekend.
Thanks,
27ft x 24ft Metal Building (A51573)
27ft x 24ft Metal...
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
John Deere Gator Utility Cart (A50324)
John Deere Gator...
TORO MBTX 2500 STAND-ON CONCRETE BUGGY (A51406)
TORO MBTX 2500...
2019 GEHL RT105 SKID STEER (A51246)
2019 GEHL RT105...
2009 CATERPILLAR 420E BACKHOE (A51406)
2009 CATERPILLAR...
