B26 has a hydraulic oil leak
   / B26 has a hydraulic oil leak #1
GeneD14
Tennessee
Kubota B26 TLB, Allis Chalmers D17 series IV, Kubota ZG-23 Mower, Kubota ZD 1211, Kawasaki Mule 610, Stihl 361, Stihl 045 AV Super, and a Stihl 660 Ported and tuned
I have a 2013 B26 with 512 hours on it. It drips about a spoon full of hydraulic oil per day. I can稚 tell exactly the source, but it appears to be running down the large square oil reservoir underneath.
I致e looked around the filters and the square oil reservoir and I didn稚 see anything obvious.
Anyone have experience with a B26 oil leak?
Any ideas where I should check next?
Thanks
   / B26 has a hydraulic oil leak #2
Buy a couple of cans of cheap engine degreaser at WalMart. Clean all of the oil away with degreaser and soap & water, then you'll be able to see where it's leaking.
   / B26 has a hydraulic oil leak #3
Then after it dries...roll it in flower and look for a wet spot...:D
sorry could not resist...!
seriously though...it seems if it was on a pressure line there would be more oil so the obvious things to check are the return lines and where they connect to the tank...
Good ideas.
I will try narrowing the leak down this weekend.
Thanks,
Giyi Trencher (A57149)
2013 Ford Fusion SE Sedan (A56859)
2013 Ford Fusion...
PALLET OF CULTIVATOR PARTS (A52708)
PALLET OF...
15' WICK BAR W/ ALUMINUM MOUNTS (A52708)
15' WICK BAR W/...
2007 Case IH 275 Tractor (A59814)
2007 Case IH 275...
Jumper Cables (A57149)
