B2410 with Pat's Easy Change?
   / B2410 with Pat's Easy Change? #1
Royboy
I finally bought Pat's Easy Change and am wondering if my B2410 will need a top link extender to work correctly with the Pat's System?
If so, can anyone recommend one that will fit and work.
Thanks!
   / B2410 with Pat's Easy Change? #2
Thanks!
I was wondering the same thing for a BX25D. Does anyone use this attachment on a BX25D? How does it work.
   / B2410 with Pat's Easy Change? #3
Just get a category 1 toplink that is a few inches longer than the factory one. Tractor supply sells them in different lengths. Measure how long the easy change extends your lift arms and buy a toplink the much longer than your current one.
   / B2410 with Pat's Easy Change? #4
I got a longer top link when I put Pat's on my L2501. My existing top link was at the limit. I measured the length and used that for a mid range on the new one. I had to get a longer drive shaft for my mower, too. It had been marginal but Pat's put it to scary.
   / B2410 with Pat's Easy Change? #5
Got rid of the turnbuckles and got Pat's quick changers installed.
2015 Ford F-350 4x4 Ext. Cab Liberator 3,200LB 1.5 Ton Crane Mechanics Truck (A55973)
2015 Ford F-350...
2001 Workhorse Custom Chassis P42 Delivery Truck (A59230)
2001 Workhorse...
1985 Ford Ltl9000 Tender Truck (A61307)
1985 Ford Ltl9000...
10 X6 MANIFOLD (A58214)
10 X6 MANIFOLD...
2017 FORD F-450 XL BUCKET TRUCK (A58375)
2017 FORD F-450 XL...
2018 International DuraStar 4300 2,000 Gallon Water Truck (A59230)
2018 International...
