B2410 voltage regulator
/ B2410 voltage regulator #1
bfarr
Central Pennsylvania
B2410
Hello everyone. What should the voltage output be of the voltage regulator on a b2410? I have been having a battery issue and and I’m only getting 12.37 volts with tractor running.
Thanks.
/ B2410 voltage regulator #2
Should be 14 volts. Does your tractor have a 'Dynamo' or an alternator? I believe the regulator is built into the alternator on Kubota tractors if I'm not mistaken. The 'Dynamo' will have an external regulator.
Dynamo with the regulator separate.
Dynamo output is 20.1 AC
/ B2410 voltage regulator #4
Someone here will know.
Info would be in the WSM of any model with the dynamo.
20V AC sounds low,and you should certainly see something like 13.5VDC or higher.
Good Luck!
/ B2410 voltage regulator #5
The dynamo's are very simple and hardly ever fail. Just a couple magnets and a field winding. Have no idea where the voltage regulator is but it cannot be very expensive to replace.
(6) SHANK RIPPER BEDDER W/AUTOMATIC SHANK TRIP (A64280)
(6) SHANK RIPPER...
Titan Attachments Forks (A64126)
Titan Attachments...
JRB 52" HANG-ON WHEEL LOADER FORKS (A63276)
JRB 52" HANG-ON...
2020 Chevrolet Equinox AWD SUV (A61574)
2020 Chevrolet...
2025 GIYI GY-P45 Hydraulic Breaker Mini Skid Steer Attachment (A61572)
2025 GIYI GY-P45...
2017 Cadillac Federal 70 IN Limo - 30,529 Miles w Premium Coachwork by Federal (A63688)
2017 Cadillac...
