B2410 voltage regulator
/ B2410 voltage regulator #1
bfarr
Central Pennsylvania
B2410
Hello everyone. What should the voltage output be of the voltage regulator on a b2410? I have been having a battery issue and and I’m only getting 12.37 volts with tractor running.
Thanks.
/ B2410 voltage regulator #2
Should be 14 volts. Does your tractor have a 'Dynamo' or an alternator? I believe the regulator is built into the alternator on Kubota tractors if I'm not mistaken. The 'Dynamo' will have an external regulator.
Dynamo with the regulator separate.
Dynamo output is 20.1 AC
/ B2410 voltage regulator #4
Someone here will know.
Info would be in the WSM of any model with the dynamo.
20V AC sounds low,and you should certainly see something like 13.5VDC or higher.
Good Luck!
/ B2410 voltage regulator #5
The dynamo's are very simple and hardly ever fail. Just a couple magnets and a field winding. Have no idea where the voltage regulator is but it cannot be very expensive to replace.
2008 Kaufman Wedge Trailer (A62613)
2008 Kaufman Wedge...
2015 Ford Explorer AWD SUV (A61574)
2015 Ford Explorer...
2016 Ford Explorer AWD SUV (A61574)
2016 Ford Explorer...
2012 Infiniti QX56 (A61574)
2012 Infiniti QX56...
1983 John Deere 2940 Tractor (A62613)
1983 John Deere...
2015 Ford Escape SUV (A61574)
2015 Ford Escape...
