B2410 delivered!
/ B2410 delivered! #1
chainsawrich
new jresey
B2410
B2410 delivered last monday and I finally had time this sunday to get 3 1/2 hrs seat time. I have to say this machine is totaly, completely, utterly, positivly the greatest thing since sliced bread! It is more than I expected in evey manner. The FEL is great and the Land Pride rake is heavy duty all the way. Pleanty of power in 4 wheel drive. HSD is a dream. The only thing I need to do is get some weight on the bar turf tires as they loose tracktion before the machine will bog down. Any body have any tips on wheel weights versus tire ballist?. I highly recomend this unit. It's no toy and all buissness!!! /w3tcompact/icons/grin.gif
/ B2410 delivered! #2
Congrats on the new B2410! Here is a pic of my 2410 spreading gravel around my new water well. Sometimes I like the BX best and other times the 2410, she loves me, she loves me not. In this pic I am liking the 2410 best /w3tcompact/icons/smile.gif .
Notice how shiney and happy my 2410 is, also notice the R4 tires and the Kubota 7548 boxblade. The FEL spread the gravel but it was the boxblade that made it nice and smooth afterwards. J
/ B2410 delivered! #3
Here the loader is about half full, in about 20 minutes I had spread about 8 tons of gravel and this is this last little bit I saved for a pot hole in my road.
Don't look like no toy to me either. /w3tcompact/icons/smile.gif J
/ B2410 delivered! #4
I would have been crawling the walls if I had to wait that long before I got seat time on a new tractor that was just setting there and waiting /w3tcompact/icons/crazy.gif
By the sounds 3 1/2 just wasn't enough seat time,better call in to work and say you got a fever..seat fever..and than enjoy yourself once again. /w3tcompact/icons/wink.gif
/ B2410 delivered! #6
i have the 1998 version of your machine b2400, and i have to agree with all u say, although i have r4's on mine.
/ B2410 delivered!
Frank do you use ballist or tire weights on your machine? If so do they make a real differance in traction.
/ B2410 delivered! #8
i have neither filled tires or wheel weight, when i need weight i usually have the back blade on. a few times when i did not have blade on and was moving dirt, i would have like a little extraweight, but not many times.i move a lot of snow, and dirt and do some brush clearing and tree moving and the only time i really run out of traction is trying to move or pull stumps. see attached pic for an idea of some of the snow i move with no problem.
/ B2410 delivered! #9
I'm on the fence regarding buying a B7500 or a B2410. Do any of you guys have experience with both? Not sure if it's worth the extra $2,000.
/ B2410 delivered! #10
Dave,
Ask this question as a seperate post, and you should get many replies. I own a B-7500 and am very pleased, the major differences position control and 3 extra horses. $2000 difference will depend on chores you want to accomplish.
Good Luck both are fine machines you really can't go wrong.
/ B2410 delivered! #11
Dave, that is a good question and probably deserves it's own thread. I think both are fine units. To me the BX is for the guy who needs a good mowing machine and the flexibility to undertake other tractor tasks and the 7500 is for the guy who needs to do a lot of those "other" tasks but still needs the flexibility to use a MMM. The B2410 is like the 7500 but just has a tad more capacity in the loader, a few more horses/torque, a few niceities such as rear hydrualic output block, rear closeout ( a few bucks and it fits the 7500), nicer seat, more 3-point capacity, larger rear tires, a bit more weight, slightly wider (mostly due to larger tires) and--and Position control. Position control is very useful and I am learning everytime I use the tractor how helpful it is. It is, however, probably not a break or make factor as I am sure you could do well enough without--but it is a nice feature. The Bi-speed is kinda kewl too (B2410HSDB---only). On the other hand, for that 1,500 to 2,000 dollars you could get a KK 4 foot cutter, a boxblade, a rear blade, and a dinner out with your wife to celebrate the new 7500, tough choices. I got the 2410 over the 7500 because I wanted a solid increase in performance over the BX without stepping up to the larger, longer, heavier B2710 and 2910, I think I accomplsihed that mission requirement. Good luck.
J
2015 Ford F-250 Knapheide Service Truck (A64556)
2015 Ford F-250...
(4) 29/11-15 Dirt Track American Racer Tires (A64127)
(4) 29/11-15 Dirt...
2019 International LT625 Sleeper 48 (A62613)
2019 International...
213064 (A64276)
213064 (A64276)
New 5400LB, Rachet Binders and G70 Chains (A62679)
New 5400LB, Rachet...
2013 Atlas Copco XAS 400 JD7 Portable Air Compressor 125 PSI - Trailer Mounted - Tier 4 (A63689)
2013 Atlas Copco...
