b2400 steering slack
/ b2400 steering slack #1
ericb2400
KY
kubota B2400
my b2400 has about 1/4 turn of slack in the steering wheel. any ideas where the slack come from or how to remove it? Thanks
bump :confused:
/ b2400 steering slack #3
The power steering unit is bolted to the tractor. Any chance the bolts are loose?
Thanks. Ill give that a look.
Sent from my iPhone using TractorByNet
Ok. Finally got around to looking at it.
The nit on the linkage is loose. When I put a wrench on it, the whole ball joint spins. I don't see a way to hold the joint while tightening the nut.
/ b2400 steering slack #6
Try prying up or down with something between the pivot arm and ball joint end. In order to tighten up the ball in the socket so it does not spin. Additionally the threads may be rusty and the bolt slightly seized in place,,, soak the threads in some solvent like PB Blaster.
Thanks for the idea ill give that a try and report back.
👍👍 thanks for the reply. I gave it a shot this morning and got it to snug up a good bit. Then spent about 6 hrs mowing. Easer to do without all that slack. 👍👍
/ b2400 steering slack #9
Some times a simple fix works the best. Glad ya got back to mowing in full control.
CATERPILLAR 926M WHEEL LOADER (A60429)
CATERPILLAR 926M...
Mini Skid Steer Mount Plate, 5/16" Thickness (A62679)
Mini Skid Steer...
2004 Ford F-550 Single Cab Flatbed Truck, VIN # 1FDAF56P94EC72605 (A65563)
2004 Ford F-550...
2024 CATERPILLAR 68" HYD 4IN1 BUCKET (A62129)
2024 CATERPILLAR...
2014 QUALITECH FUEL POD TRAILER (A65643)
2014 QUALITECH...
INSPECTION (A65583)
INSPECTION (A65583)
