B2400 Possible Hydraulic Cooling Problem
/ B2400 Possible Hydraulic Cooling Problem #1
Yandaddy1110
Elk River, mn
Yanmar YM1110D, John Deere 955
For some time I run my B2400 for more than 10-15 minutes and I lose hydraulic pressure, the 3ph will not lift the 600lb rock box and the loader will not lift the front tires off the ground. If I let the tractor sit for a few hours , the hydraulics return to normal. I assumed the problem was aeration of the hydraulic fluid due to a leak in a sump line. Well, I have fixed the leak and thought all was well till I mowed for 45 minutes today and the hydraulic power loss returned as usual. This time after some investigation I discovered the hydro is very warm, hurts to the touch after 4 seconds,and the mid pto is also very warm. The hydro filter is cool as are the hydraulic lines to the cooler. The loader inputs lines are warm to the touch. I know from experience that the filter and lines should all be warm. Could there be blockage somewhere? With the leak repair I did clean the sump screen and changed the filter.
I might add that I do lock the 3ph up when running the tractor I wouldnt think this would be the cause, the owners manual says nothing about running the tractor in locked position. Anyone have any experience with a problem like this?
/ B2400 Possible Hydraulic Cooling Problem #2
Is the hydroatatic trans full of fluid
Yes it is full of hydraulic fluid I checked that.
KBH Tender Trailer (A63689)
KBH Tender Trailer...
1999 Playbuoy Pontoon and Boat Trailer (A62613)
1999 Playbuoy...
2009 VOLVO VHD BOBTAIL VACUUM TRUCK (A63569)
2009 VOLVO VHD...
2007 KENWORTH T800 TRI/A ROLLOFF TRUCK (A59914)
2007 KENWORTH T800...
2018 Infiniti QX60 SUV (A64557)
2018 Infiniti QX60...
2012 POLAR TANK TRAILER (A63569)
2012 POLAR TANK...
