B2400 Possible Hydraulic Cooling Problem
/ B2400 Possible Hydraulic Cooling Problem #1
Yandaddy1110
Elk River, mn
Yanmar YM1110D, John Deere 955
For some time I run my B2400 for more than 10-15 minutes and I lose hydraulic pressure, the 3ph will not lift the 600lb rock box and the loader will not lift the front tires off the ground. If I let the tractor sit for a few hours , the hydraulics return to normal. I assumed the problem was aeration of the hydraulic fluid due to a leak in a sump line. Well, I have fixed the leak and thought all was well till I mowed for 45 minutes today and the hydraulic power loss returned as usual. This time after some investigation I discovered the hydro is very warm, hurts to the touch after 4 seconds,and the mid pto is also very warm. The hydro filter is cool as are the hydraulic lines to the cooler. The loader inputs lines are warm to the touch. I know from experience that the filter and lines should all be warm. Could there be blockage somewhere? With the leak repair I did clean the sump screen and changed the filter.
I might add that I do lock the 3ph up when running the tractor I wouldnt think this would be the cause, the owners manual says nothing about running the tractor in locked position. Anyone have any experience with a problem like this?
/ B2400 Possible Hydraulic Cooling Problem #2
Is the hydroatatic trans full of fluid
Yes it is full of hydraulic fluid I checked that.
2008 Case IH JX80 Loader Tractor (A66285)
2008 Case IH JX80...
2019 FORD F350 4X4 PICKUP TRUCK (A59914)
2019 FORD F350 4X4...
2016 JOHN DEERE 7210R TRACTOR (A65054)
2016 JOHN DEERE...
Planter Seed Plates (A65640)
Planter Seed...
2020 INTERNATIONAL LT625 SLEEPER (A59910)
2020 INTERNATIONAL...
Galion T-400 Motor Grader (A65579)
Galion T-400 Motor...
