B2320 fuel filter bowl does not stay full
   / B2320 fuel filter bowl does not stay full #1
mcrame01
Quincy, IL
Kubota B2320
I was hoping someone might be able to help me out with some fuel issues that I have been having with my B2320. For the past month, the tractor has been cutting out. At first, I thought it might be a seat sensor so I jumpered both of them to see if that would resolve the issue.
It did not solve the issue. As I started to mow, I noticed that the fuel filter bowl started to empty and the fuel line started to go down until it hit the bottom of the filter. Sure enough, once that happened my tractor started to die and the RPMs lowered. It does not die but gets pretty close. As it starts to die, you can see the fuel run down the side of the filter bowl and eventually it fills again.
Once it is full, the tractor runs fine until I start using the mower or push the pedal to go forward/backward. The tractor will sit and idle just fine and the bowl only lowers when I'm moving and mowing. Sometimes it will even run for 5 or 10 minutes.
Once I saw the fuel lower, I stopped and shut off the tractor. I then took the bowl off and fuel continued to run out. I pushed up on the spring loaded fuel "stopper" (not sure what it is actually called) and the stream stopped. I started to mow again and the fuel continues to lower. Is it possible the top part of the fuel filter bowl is bad? Does anyone have any ideas?
Thanks for the reply. Another thing that I noticed when the problem first started was that it would run just fine if I would completely fill that fuel tank. I did that for 3 or 4 weeks but now that problem persists regardless.
   / B2320 fuel filter bowl does not stay full #4
You might also check the tightness of the fuel bowl and replace the o-rings for it. I think the 2 o -rings for my B3030 cost less than $2--a bargain.
Kenny already mentioned part of this.
   / B2320 fuel filter bowl does not stay full #5
My fuel bowl vibrated off and of course the motor shut off, I found it and screwed it back on but did not notice the o-ring was missing. Would not start until I bled the fuel line. It was dripping fuel but the motor still ran. If yours is like my L2800 the bowl has two o-rings. The large one goes around the top of the bowl and the small one is attached to the center of the filter. May not be your problem but who knows, good luck.
   / B2320 fuel filter bowl does not stay full #7
For the filter to be sucking down means there is a restriction up stream from the filter. Either a kinked or collapsed fuel line or something restricting the outlet from the tank.
Thanks for all the ideas. I will check the o-rings. If that doesn't work, I will check upstream as well.
   / B2320 fuel filter bowl does not stay full #9
Also check for something floating around in the fuel tank. ie wood chips or ?.
2010 Freightliner M2 106 MedTec Ambulance (A46683)
2010 Freightliner...
2011 Chevrolet Cruze Sedan (A46684)
2011 Chevrolet...
Temporary Bolt on tail lights  (A47371)
Temporary Bolt on...
2020 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A45678)
2020 FREIGHTLINER...
2017 Ditch Witch JT20 (A47371)
2017 Ditch Witch...
Range Road RR5018 Band Saw Mill  (A47371)
Range Road RR5018...
