Loader B2231 brand new - big problem with stability
   / B2231 brand new - big problem with stability #1
maciek8791
Yanmar
Hello, since three days I am a happy owner of b2231 cab with FL.
So far I used the machine mainly for FEL work (moving dirt and sand).
I have very serious issue with the stability of rear wheels. I have watched several videos about the FL safety, therefore I keep the loader low when its full. But still, even a small hole in the ground and I have very bad effect - when rear tires hit the obstacle the whole cabin is bouncing left and right. I can manage that by driving carefully and slow, but I wonder if this is maybe tires or rear ballast issue. I join a photo of my machine. Don't You think that those tires are too narrow? The problem is that my dealer allready told me, that he cannot offer any spacers to make the machine wider and he also refused to offer any additional ballast in the tires. At the moment I am only thinking of attaching the box blade at the back which will come on next week - it has weight of 260kgs. Thanks in advance of any comment, for me this is a safety issue, I am just not sure if my setup is correct, maybe those tires are simply too small?
   / B2231 brand new - big problem with stability #2
Do you use it on slopes? All tractors bounce like this when hitting holes etc, should not be a stability issue on flat ground and the loader low to the ground. Of course a small tractor with small wheels doesn't have a lot of ride comfort, but a rear weight will help to keep load of the front axle and the rear down on the ground.
   / B2231 brand new - big problem with stability #3
When your running loads in your FEL you will need to offset some weight. The box blade should be enough for stability but the ride isn’t going to get much better. Ensure your tires have the correct inflation especially the front. This will also help with keeping your FEL level for scooping.
   / B2231 brand new - big problem with stability #4
Are you operating with any implements or ballast box on the back? If not you should.
Remember that you are operating a SCUT not a crawler loader or industrial wheel loader. If you plan to do a lot of earth moving you should consider a bigger and more suitable machine. Maybe consider a skidsteer. Otherwise go slow, use a heavy ballast and avoid sudden movements and sharp turns. Your bucket looks nice but its pretty long meaning it pushes your center of gravity forward like a set of forks would. That might be part of what you are seeing stability wise.
   / B2231 brand new - big problem with stability #5
Sounds like you need a ballast box.
SDT
   / B2231 brand new - big problem with stability #6
for one when the bucket is loaded you should always travel with it close to the ground.
so how much do you have in the tires now? were they not loaded as much as possible when the dealer did it the first time?
   / B2231 brand new - big problem with stability #7
You need some weight on the back. Tractors aren’t designed for loader use without counter weight. My L3800 is barely enough with loaded tires and a box blade. You need more weight than just the BB but anything is better than nothing.
   / B2231 brand new - big problem with stability #8
Spacers and tire ballast is available for that machine. You have to pay for them. Did you discuss price with the dealer?
   / B2231 brand new - big problem with stability #9
not a big fan of a lot of weight banging around on the 3-point linkage. We see posts about broken linkage or broken tractors.
Ballast in the tires doesnt wear anything on the tractor, doesnt overload bearings etc. Hopefully the bucket is paired with the tractor so it wont hold more then the tractor should handle.
I am quite pleased with my Kioti. Ever since I filled my rear tires I have never needed any counterbalance.
I can carry a full bucket and comfortably move around and still be stable to the ground. I have a 15-20 degree incline area at the end of the orchard. With the bucket full it climbs it nicely.
   / B2231 brand new - big problem with stability #10
Do you have your rears at the widest spacing possible?
My M4700 has 5 or so possible widths for the rears. I don't know about the B2231.
   / B2231 brand new - big problem with stability #11
But weight on the 3pt is the only thing that saves your front axle, no normal tractor brakes down by carrying weight on the rear.
Yes of course, I am open to pay for it, however the dealer told me that he does not have those items in the price list. I will try with another dealer perhaps or directly with Kubota, to double check that. Thank You for Your advice.
   / B2231 brand new - big problem with stability #13
Tire ballast, in the form of liquid in the tires, such as beet juice, can be installed by any tire dealer that deals with tractor tires. That will be most tire dealers in rural areas.
Weight on the 3 pt is essential to reduce the load and wear on the front axle, and as has been pointed out, will not harm the tractor if kept within the manufacturer's specs and the 3 pt kept reasonably snug so it is not flopping around.
   / B2231 brand new - big problem with stability #14
You are working with a sub-normal unhelpful, or at best minimally equipped dealer. That is just crazy for the dealer to present you with that position and not even suggest good alternatives. Of course get fluid in your rear tires which will help a lot during FEL work. Then decide what else to hang on the rear (during FEL work) such as a ballast box or box scraper, etc. If there is usually plenty of room a good heavy bush hog back there works fine. You can certainly put spacers on the rear (the wider the better if using it on steep ground) but lateral stability is probably not your issue if you just get enough weight in the back. See other threads regarding Amazon selling 2" spacers under $60 and from the posts I'd guess they probably fit your machine. Install your self. If never using a MMM then go to wider spacers (if you need them at all.)
   / B2231 brand new - big problem with stability #15
Yep. I just bought a tractor (L2501) after shopping several brands. EVERY dealer of every make stated that loaded tires are included in the cost.
You've stumbled on a lousy dealer.
   / B2231 brand new - big problem with stability #16
Have your tires filled, bolt on some high-quality wheel spacers like Bro-Tek, and put some weight on the back. I would not bolt on some questionable, cheap Chinese spacers off of EBay or Amazon. Good luck......
   / B2231 brand new - big problem with stability #17
Looks like the poster`s tractor is bigger than a BX so good luck finding inexpensive wheel spacers on Amazon or ebay or walmart. Might be there but not easy to find.
However I can say that for a BX the so called cheap wheel spacers are a good value. Well made and better than satisfactory quality. I have a set of 1.25 inch on my BX2200, the MMM limited width. My son in law put 2inch spacers from a different vendor on his BX23S. Both are well made. And MUCH less cost then somewhere like brotek.
Point is, do not bad mouth something if you have no first hand experience with it.
   / B2231 brand new - big problem with stability #18
I’m badmouthing a bunch of cheap crap with unknown heritage. There are hundreds of pictures of failed cheap crap on the internet, I don’t believe I’ve seen a failure of a quality spacer like Bora or Bro-Tek. A failed spacer at the wrong time can cost someone their life, and for what? To save a few hundred dollars? My Bro-Teks on my new LX3310 were just under $500 delivered, they have a warranty, the correct fasteners, and excellent product support. I have no problem with that, YMMV.
(32) FLOOR TRUSSES (A60432)
(32) FLOOR TRUSSES...
2018 Ford Explore AWD SUV (A59231)
2018 Ford Explore...
CATERPILLAR 72" HANG-ON WHEEL LOADER FORKS (A60429)
CATERPILLAR 72"...
2020 DRAGON ESP...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
Miller Big 40 Portable DC Arc Welder Generator (A55973)
Miller Big 40...
