B2230 Engine prob at high RPM
   / B2230 Engine prob at high RPM #1
Merlin
Northern Teir, PA
BX24 And RTV 900 with Plow
Hi Guys My Brother in law has a B2230 2004 and when he runs it at Hi rpm it cuts out and smokes. Also no matter how often and how long he runs it the temputure guage never goes above cold. Is Their anybody out there that has ever had this problem?
   / B2230 Engine prob at high RPM #2
Could it be as simple as one of the fuel filters?
I Dont know but I will tell him to check that. He said that when it is cold out it seems to run better than in the summer when it is warm.
   / B2230 Engine prob at high RPM #4
ID tell him to change his air filter also.
ALAN
   / B2230 Engine prob at high RPM #5
cold? how cold? gell the fuel or frease some water in the fuel cold?
I would say in the 30's but his fuel seems good he does use additives for gelling not sure if he has ever put fuel antifreeze in the tractor though. But I would not think that is the problem since it runs better when it is cold out. I am leaning towards the fuel filter my self. Or the other idea I had might it be vapor locking some how? But the other strange thing is that according to the temp gauge it never goes above cold. The dealer told him that was normal.
   / B2230 Engine prob at high RPM #7
Diesels don't vapor lock. If the fuel filter swap, there are two if its like my BX24, and the air filter swap doesn't fix it then I'd try a good dose of some diesel injector cleaner like the Power Service Diesel Kleen in the silver bottle .....
   / B2230 Engine prob at high RPM #8
Sounds like the air filter is clogged.
Have him test it w/ it out but don't run it too long without it.
Merry Christmas
Sounds like good advice I will be seeing him tonight at Christmas dinner and will let him know. Thanks so far guys if you think of anything else let me know. I will let you know how he makes out. Merry Christmas to all of you
Merle
Ok Guys I just talked to him he said that he has replaced the fuel filters and the air filter but it still does not help. he said he tried it without the air filter and it did run better. So he bought a new air filter and then it went back to its old ways. He also said that when it is warm out it runs better then when its cold out. Cold air seems to be the problem any suggestions???
2010 POLARIS RANGER 4X4 4 SEATER UTV (A51222)
2010 POLARIS...
2020 FREIGHTLINER CASCADIA SLEEPER (A51222)
2020 FREIGHTLINER...
2022 New Holland Workmaster 120 MFWD Compact Utility Tractor (A52128)
2022 New Holland...
2000 Ford Ranger (A50515)
2000 Ford Ranger...
KUBOTA RTV X1100C UTV (A51406)
KUBOTA RTV X1100C...
2023 TAKE 3 TRAILER 3 CAR TRAILER (A52141)
2023 TAKE 3...
