B2150 Hydro peddle adjustment?
/ B2150 Hydro peddle adjustment? #1
Danno
Kubota B2150
Seems that the peddle that controls f&R movement on my B 2150 does not fully return to neutral when you remove your foot. I have to give it a little rearward nudge to fully stop forward travel. Any ideas?
Thanks
/ B2150 Hydro peddle adjustment? #2
Danno, have you looked at the linkage under the floor. There is an adjuster under there, but I just don't know how to describe it. There's a good chance that if you look at it while someone moves the pedal back and forth, you'll see how to do it.
Bird
/ B2150 Hydro peddle adjustment? #3
I have the same tractor and the same problem. I have looked under there and concluded that there is a small hydraulic or shock absorber type of device that returns the pedal to the neutral point. I could not find an adjustment, so I lubed the pedal mechanism. No change. I have learned to live with it and just tap her into reverse when it creeps.
Good luck and please post if you find a fix that does not involve replacing the device.
Thanks guys..it might be internal who knows..I can live with it though
/ B2150 Hydro peddle adjustment? #5
DANNO, DO'NT LIVE WITH IT!!!!!!!!!
You can fix that.... Pull the cover that "hides" your HST filter (the one between your legs should have 4 thumb screws) You will see a threaded rod sticking up with 2 nuts on it thats the adjustment for the spring that returns the hst pedal to neutral.Loosen the jam nuts and tighten the spring as much as you need to then spray some lube on the linkage up under and toward the back right side of the tractor, should be a "V" shaped bracket up under the frame above the front wheel drive shaft rear u-joint (you really got to squirm under to see it) and lube that little round bearing. Also grease up the pedal and that should do the trick........
The printer is printing up your post as I type this. Thanks a bunch I just got done plowing snow 8" here in PA and I'll give it the check up this weekend. Sounds like a real solution to the "creeping peddle! Sure appreciate the info.
/ B2150 Hydro peddle adjustment? #7
I pitch in (thirdly)and say that I have the same problem with my B2150 HSD. I am curious to see how the fix works. Keep us posted. I'll live with mine until probably Spring, but would like to get it working properly if possible.
Kelvin
2019 Mirage 20' x 8.5'  Enclosed Trailer (A62613)
2019 Mirage 20' x...
2012 KENWORTH T370 CAB & CHASSIS (A65643)
2012 KENWORTH T370...
2017 Ford F-250 4x4 Ext. Cab Pickup Truck (A64556)
2017 Ford F-250...
2023 JOHN DEERE 450P LGP CRAWLER DOZER (A64279)
2023 JOHN DEERE...
1999 Ford F800 Dump Truck, VIN # 3FEXF8019XMA05457 (A65563)
1999 Ford F800...
UNVERFERTH H25 - 25' HEAD CART (A64277)
UNVERFERTH H25 -...
