B2150 40 Amp Alternator Set Up
   / B2150 40 Amp Alternator Set Up #12
Aquetrac,
I bit the bullet and did the upgrade on my 2150 a few years ago. Bought all the Kubota parts except the alternator which came from Ebay. Expensive but well done by Kubota. It is exactly as you describe with the idler pulley setup. I did post a parts list here as well. The only area to save a few bucks is the air cleaner bracket. They replace the original with a fancy one that has a rubber strap so you can swing the air cleaner assy up to check or change the filter. The old one would have to be un-bolted but would still work fine....
I don't regret it, I run all the accessories I need now in the winter without worrying about the battery....
Best of Luck,
Marty
2012 Ram 4500 Versalift TEL29N 29ft Bucket Truck (A50323)
2012 Ram 4500...
Safety Basket (A50121)
Stump Bucket (A50322)
BUSH HOG 2615 - 15' BATWING MOWER (A51243)
BUSH HOG 2615 -...
2017 Ford F-150 Ext. Cab Pickup Truck (A50323)
2017 Ford F-150...
Western Snow Plow with Brackets (A50515)
Western Snow Plow...
