B2150 40 Amp Alternator Set Up
   / B2150 40 Amp Alternator Set Up #12
Aquetrac,
I bit the bullet and did the upgrade on my 2150 a few years ago. Bought all the Kubota parts except the alternator which came from Ebay. Expensive but well done by Kubota. It is exactly as you describe with the idler pulley setup. I did post a parts list here as well. The only area to save a few bucks is the air cleaner bracket. They replace the original with a fancy one that has a rubber strap so you can swing the air cleaner assy up to check or change the filter. The old one would have to be un-bolted but would still work fine....
I don't regret it, I run all the accessories I need now in the winter without worrying about the battery....
Best of Luck,
Marty
1500 Gallon Water / Chemical Tank (A50860)
1500 Gallon Water...
Holiday Rambler Alumascape Travel Trailer (A48082)
Holiday Rambler...
2025 K0720 UNUSED Metal Farm Driveway Gate Set (A50860)
2025 K0720 UNUSED...
2013 Big Tex 16GP-20 Gooseneck Trailer (A50860)
2013 Big Tex...
2016 Kawasaki 70 TM 7 Articulating Wheel loader (A51039)
2016 Kawasaki 70...
2017 terex warrior 1800 screener (A50322)
2017 terex warrior...
