B21
   / B21 #1
daro
Alleghany County,NC
Thanks again for all of the advice.
Does anyone have any (+/-) feedback about the B21.
Though I have not seen this tractor or know the maint/track record it seems worth looking at.
I was just offered a B21 w/ RT, RMRM, RB, BB, & PHD for 5K. Any suggestions welcome and thanks in advance for your knowledge and time.
Daro
   / B21 #2
IS that like 5K as in $5000.00???
Must be an offer from a REALLY good friend, some one that has no idea the value of what they are selling or a total scam. Of course it may be a REALLY high hour beat up machine but that sounds like a real low price for a B21 and all those attachments.
I have heard the B21 is a darn good little machine for its size. I have a L35 and it amazes me what it can do, as long as you keep its size/weight class in perspective of course.
Hutch
   / B21 #3
I agree with Hutch. I briefly considered buying a new B21 in 1995, but money was short and I didn't really need the backhoe so I bought a B7100 instead, but if I'd had a little more money, I'd have bought he B21.:)
   / B21 #4
Price sounds too good to be true. Momma always told me there's no such thing as a free lunch.
   / B21
Thanks,
The flyer sent to me doesn't show a BH.
Was this std or optional?
Sill waiting to get the history on this tractor.
Thanks,
Daro
   / B21 #6
Daro, the B21 was a TLB (tractor/loader/backhoe) but of course the backhoe could be removed to use the tractor with other implements. While I can't say for sure, I don't think Kubota sold them without the backhoe.
   / B21 #7
Thats a good price even without the backhoe. As mentioned, I would be suspicious of that price.
I don't know about the B21, but I believe you can order a B26 w/o the backhoe. While I was researching the B26, I ran across issues with the B21 tranny. Mechanic at local bota dealer said they see "a lot" of B21 tranny overhauls.
   / B21 #8
I own a B21 and it is a great machine. They are popular in the rental business since the are built to the same level as an industrial tractor. I am sure the reason for transmission problems is the rough use in the rental business.
I have operated a lot of backhoes over the years and I can tell you the little B21 is a fine machine and compares with the best, but on a smaller scale.
I used mine to excavate a pad for a new home, a large workshop, a guest house, put in a septic system, water system bury my power lines, and dig a pond. I also run a 5' tiller. I use it like a fork lift with a set of forks. It is easy on fuel and has adequate power for everything. Actually I would like a bit more on the backhoe, but I tend to really work it like a big Cat, or try to. I put about 300 hours on it last year.
The fact that it does not have a back hoe, suggests that it was swapped off and sold with the 3 point hitch. The backhoe connections should still be in place since they are built into the frame. I would venture to say it could be added.
They usually hold value well.
Curt in Central Oregon
   / B21
I read a couple of threads about a tranny rebuild. I could do it but dedicating the time would have to be justified and its a a lot of work I don't need at this moment. The B21 does appear to be a very stout tractor for its size and HP and is perfect for my needs.
Your feed back continues to help and is greatly appreciated. Thanks again.
Daro
   / B21 #10
Around here used B21's with low hours go for 18-20K with a backhoe. They do look like pretty stout machines! Most of the ones I've seen for sale around here are from dealerships that have had them in the rental fleet. I have a friend who has had one for years, and he has done a remarkable job on his property with it. Of course, he is the kind of guy that does a remarkable job restoring antique cars too. :)
10ft Enclosed Cargo Trailer (A53424)
10ft Enclosed...
2000 CATERPILLAR 140H MOTOR GRADER (A51406)
2000 CATERPILLAR...
Year: 2005 Make: Ford Model: F-150 Vehicle Type: Pickup Truck Mileage: Plate: Body Type: 4 Door C... (A54814)
Year: 2005 Make...
43029 (A51691)
43029 (A51691)
