B20 Range Selector Lever operation
   / B20 Range Selector Lever operation #1
MikeInOnt
I need a wee bit of clarification with regards to a B20 Range Selector operation.
I understand the "U" pattern, starting with High range in the upper right position, down through a neutral, into Mid range at the base of the "U", and now here is the question. From the Mid range position I take it the pin on the lever is supposed to slid into a second lever below the surface of the cover, and from this point the second and first lever progress forward to the second neutral, and then forward to low range.
I just want to confirm that this is the correct operation as I appear to be able to slide the lever forward towards Low without engaging the second lever via the pin. (or now that I'm back in the house am I just thinking I did......???)
Thanks in advance!
Mike In Ont
   / B20 Range Selector Lever operation #2
A little wear and or bent "gate/U" will cause the linkage to not engage the pin. Also make sure the gate is not loose.
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A49461)
2021 Ver-Mac...
2005 PETERBILT 357 TRI AXLE DUMP TRUCK (A51222)
2005 PETERBILT 357...
2014 Peterbilt 320 Altec AH150 150ft. Material Handler Bucket Truck (A49461)
2014 Peterbilt 320...
1977 Allis Chalmers 7060 Tractor (A50514)
1977 Allis...
2019 CATERPILLAR 326FL EXCAVATOR (A51242)
2019 CATERPILLAR...
CATERPILLAR 12" BACKHOE BUCKET (A51242)
CATERPILLAR 12"...
