B1550 sputters to life
   / B1550 sputters to life #1
SteveInMD
Platinum Member
Brookeville, MD
TC33D
My B1550 has not been starting as well as it used to. It starts, but it takes more cranking than it used to. I still get a little puff of black some as it comes to life. My understanding is that a bad glow plug would result in white smoke (unburned fuel) at startup. Am I wrong on that? I've replaced the fuel filter, which had no effect. What else should I be looking at?
Thanks!
   / B1550 sputters to life #2
Sounds like water in the fuel. Drain fuel and put fresh in anf see if that helps.
   / B1550 sputters to life #3
I am a bit confused(not unsual for me /forums/images/graemlins/grin.gif) but you are asking about a B1550 and your profile says you have a TC33? any how , when i don't use the glow plugs my tractor cranks longer, and then gives me a black smoke, so i always ,even in warm temps give it a few sec. on glow plugs. are you sure your glow plugs are actually working?
The B1550 is technically my fathers tractor, but it's at my property for a while.
Is there a way to test the glow plugs, or should just replace them? Are there any relays that I should test or replace as well?
   / B1550 sputters to life #5
If you disconnect the wires from the glow plugs you can check them for continuity with an ohm meter. If you do not disconnect the wires you will read all of the glow plugs in parallel.
Ford 641 Workmaster (A50514)
Ford 641...
TRAILER AXLE (A51244)
2016 Ford F-450 Ext. Cab Knapheide Flatbed Truck (A50323)
2016 Ford F-450...
100 gal Water Tank (A50515)
100 gal Water Tank...
(30) 9' Pipe Fence Posts (A50515)
(30) 9' Pipe Fence...
2004 HYUNDAI V12530152-AJS 53FT DRY VAN TRAILER (A52141)
2004 HYUNDAI...
