B1550 sputters to life
   / B1550 sputters to life #1
SteveInMD
Platinum Member
Brookeville, MD
TC33D
My B1550 has not been starting as well as it used to. It starts, but it takes more cranking than it used to. I still get a little puff of black some as it comes to life. My understanding is that a bad glow plug would result in white smoke (unburned fuel) at startup. Am I wrong on that? I've replaced the fuel filter, which had no effect. What else should I be looking at?
Thanks!
   / B1550 sputters to life #2
Sounds like water in the fuel. Drain fuel and put fresh in anf see if that helps.
   / B1550 sputters to life #3
I am a bit confused(not unsual for me /forums/images/graemlins/grin.gif) but you are asking about a B1550 and your profile says you have a TC33? any how , when i don't use the glow plugs my tractor cranks longer, and then gives me a black smoke, so i always ,even in warm temps give it a few sec. on glow plugs. are you sure your glow plugs are actually working?
The B1550 is technically my fathers tractor, but it's at my property for a while.
Is there a way to test the glow plugs, or should just replace them? Are there any relays that I should test or replace as well?
   / B1550 sputters to life #5
If you disconnect the wires from the glow plugs you can check them for continuity with an ohm meter. If you do not disconnect the wires you will read all of the glow plugs in parallel.
PALLET OF HYDRAULIC HOSES (A50854)
PALLET OF...
1999 24DTA pintle hitch trailer (A51039)
1999 24DTA pintle...
2013 Chevy Silverado 2500 HD (A51039)
2013 Chevy...
5K ANNULAR BLOWOUT PREVENTER (A50854)
5K ANNULAR BLOWOUT...
2011 Jeep Cherokee Laredo SUV (A50324)
2011 Jeep Cherokee...
Case 1150G Crawler Tractor Dozer (A50322)
Case 1150G Crawler...
