B1550 FEL / Have to remove the deck???
   / B1550 FEL / Have to remove the deck??? #1
r0GuE
West PA
ex-Bota Owner
My freind told me that to use a FEL with his 1550, he has to remove the deck. Is this true and unavoidable? If it is, he will want to step in to a more adaptable machine (a BX perhaps /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif)
Any advice is appreciated.
   / B1550 FEL / Have to remove the deck??? #2
Even if you CAN use your FEL with the MMM installed, it's generally not a good idea unless it's for lightweight work like moving a little multch and the like. The deck seriously compromises your mobility in rough ground and can also get caught on "stuff" as your shuffling whatever you're moving with the loader around. It only takes a few minutes to remove or install most MMM these days, especially if the FEL is on the machine to help you out with a little extra ground clearance to pull the beast out from under the tractor or slide it back underneath.
   / B1550 FEL / Have to remove the deck??? #3
I had a 1750, the big brother of the 1550. And while it was not necessary to remove the mmm when using the FEL, I always did out of fear of getting it caught on something and tweaking that relatively delicate mower lifting thingy.
Removing the mmm deck on those little guys is a no brainer. Took me 2 minutes...and I'm mechanically bankrupt. After disconnecting, I could lift the tractor with the FEL and slide the mower out from underneath or, like the manual says, just back up and let the front wheels drive right over the mower deck.
Pete
2004 DCT PUMP TRAILER (A58214)
2004 DCT PUMP...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
2019 Harley Davidson FLHTP Electra Glide Motorcycle (A56859)
2019 Harley...
Rooster Weathervane (A55853)
Rooster...
2015 LOAD TRAIL 24+6 GOOSENECK TRAILER (A58214)
2015 LOAD TRAIL...
MARATHON 76KW GENERATOR (A55745)
MARATHON 76KW...
