Tires B series turf tires.
/ B series turf tires. #1
lawn_king
Veteran Member
Hanover massachusetts
kubota L 3540 hsdc,B 2320 hsdc & lots of other stuff!
You can set your watch by them, 400 hrs fronts, 800 hrs rears and done. Firestones & titans.
/ B series turf tires. #2
Was the life the same on the tires you had on the B7500?
Exactly the same on fronts, 400 hrs & close to bald, rears look to be close, around 800 hrs. Most of these hours are operating on turf, some fel work on asphalt, some snow work on asphalt, but the overall hours are on turf, aerating,fertilizing and spraying.
/ B series turf tires. #4
I've wondered about that in looking at them, especially on the smaller B series tractors. The tractors are tough little beasts though, and I may end up with one yet. I'm still wondering what the new series will bring besides the same visual changes we have seen in the other models.
/ B series turf tires. #6
I went through front tires in about 200 hrs. Replaced with a set of Carlisle Turf Masters. Still look new at 250 hours.
Rears are Firestone. About 480 hours on them. I have never been impressed with the Titian tires. Seem to be narrower and have a different tread.
/ B series turf tires. #7
2600 hours on my rear turfs and about 800 hours on the fronts. The fronts were replaced due to sidewall cuts.:D :D
They have seen a lot of loader work.
My B7500 had carlisle's up front & firestones rear, the B3030 has titans all around. When the time comes im going back to carlisles up front, not sure about the rears, but they will have rim guard for sure!
That is a good question, im going to guess that the rims are the same, but i dont know for sure?
/ B series turf tires. #10
lk,
How much do you use FWD? Because of all the tire scrubbing, I use mine only when needed.
Bob
I dont use the 4wd often at all, i run my fronts with a lot of pressure.
/ B series turf tires. #12
This is where balancing the air pressure can help when operating on solid surfaces in four wheel drive. It helps to set the lead lag ratio to optimize the drive system. Different makes tires not only might enhance the traction as well as life of the tires.
2012 Ford F-450 4x4 Altec Bucket Truck (A66736)
2012 Ford F-450...
2023 CATERPILLAR 259D3 SKID STEER (A65056)
2023 CATERPILLAR...
2018 FORD TRANSIT KUV (A67714)
2018 FORD TRANSIT...
2020 MACK GRANITE DUMPTRUCK (A67714)
2020 MACK GRANITE...
2017 Ford Explorer AWD SUV (A66738)
2017 Ford Explorer...
2018 CHEVROLET TAHOE (A66091)
2018 CHEVROLET...
