b 3030 quick attatch
/ b 3030 quick attatch #1
mike550
oakley,idaho
kubota B3030
looking to see if you can get the skid steer Q/A with b 3030 dealer says you cant whants to sell me one were you have to pull the bottom pins to change bucket the top of bucket has a small cradel on each side i dont whant that i think on most eny B you can get skid steer Q/A.
/ b 3030 quick attatch #2
website says only the kubota Q/A. plenty of after market stuff out there.
/ b 3030 quick attatch #3
ATI has a quick attach for the LA403 Kubota FEL.Got it with our B3030HSDC from the dealer.Others here have it as well.
/ b 3030 quick attatch #4
I'd say the nicest skidsteer style QA I've seen for the 3030 is the ATI ( ATI Corporation - Tach-All(tm) Quick Attach ). Kubota does have a QA for the 3030, but its their proprietary set-up and you are locked into the couple attachments they have available. If you are buying a new 3030, your dealer can install the ATI along with an aftermarket bucket (my local dealer uses Woods brand skidsteer compatible buckets) and give you a credit for the Kubota bucket you won't be needing. Still expensive, but the way to go in my opinion. I'm guessing the ATI and aftermarket bucket would add around a grand to the purchase price after the Kubota bucket credit.
/ b 3030 quick attatch #5
I just bought a b3030 and asked about the kubota quick release, I saw on the web site. They told me I would not want that one because it only worked with a couple kubota implement and if I wanted a quick release they mount a skid steer type mount and reweld the back of the bucket to work will that system, which had a lot more available options. I did not go for it and now I wish I had.
/ b 3030 quick attatch #6
I just got my new B3030 a couple weeks ago and the dealer installed the ATI tach all and traded me the Kubota bucket for a Woods 60" QA bucket. I added the QA weld on plate to my fork setup that I already had. This is the fastest and easiest setup I have ever used and definatly worth the money.
2014 Magnum 7696BLA Light Tower (A59213)
2014 Magnum...
2016 Nissan Altima Sedan (A61574)
2016 Nissan Altima...
2023 ASV RT-25 Posi-Track Compact Track Loader Skid Steer (A61572)
2023 ASV RT-25...
FUEL TANK (A63291)
FUEL TANK (A63291)
2021 CATERPILLAR 299D3 SKID STEER (A64279)
2021 CATERPILLAR...
2012 John Deere 6430 102HP Agricultural 4WD Tractor (A61572)
2012 John Deere...
