Axle spring seat welding
   / Axle spring seat welding #1
ericher69
Veteran Member
Ontario Canada
2008 Kubota b2920
Don't know if this is the proper term for these things?
http://www.google.ca/search?tbm=isc...&q=axle spring seats&sa=N&biw=320&bih=306#i=9
Anyway need to weld some on a 3500lbs drop axle for a trailer.
Any special considerations or prep I should do?
I am going to :
1. grind off paint from axle
2. Degrease seats and axle
3. Line up and clamp
4. Tack
5. Recheck
6. Then burn in with Lincoln SP170-T with .030 wire and CO2 (230V 3/8 capacity)
Material (seats 1/8) and axle same
7. Prime
8. Paint
9. Reassemble
Do you think I should chamfer the seat to get better penetration?
   / Axle spring seat welding #2
Should work the way you have it.
Bolt everything in place with weight on the spring perches then tack in place. Pull it apart and burn then as planned.
E/S
Don't use brake clean to degrease.
E/S
Will not be able to put weight on with springs as the axle has been brought to me without trailer
Should not be an issue
   / Axle spring seat welding #4
I did this same thing a few years ago for a guy. I placed the axle on my welding table, with crown up. Placed the seats so far in from the wheels and used a torpedo level on each seat for alignment / rotation.
He's gonna leave the existing ones in place so I figure a nice flat surface like concrete should do
Will place new ones and use angle/tubing to true up/clamp and tack
Will take pics
Here is the final product
UNUSED MOWER KING 72" HYD BRUSH CUTTER (A51248)
UNUSED MOWER KING...
2015 INTERNATIONAL PROSTAR (A53843)
2015 INTERNATIONAL...
2000 SCHWING P88 PORTABLE CONCRETE MIXER (A51247)
2000 SCHWING P88...
2025 Swict 84in Bucket Skid Steer Attachment (A51691)
2025 Swict 84in...
2010 CATERPILLAR 140M MOTOR GRADER (A51246)
2010 CATERPILLAR...
2015 Ford F-550 Godwin 184U Crew Cab Mason Dump Truck (A51692)
2015 Ford F-550...
