3-Point Hitch axle housing failure
   / axle housing failure #1
gejandsons
john deere 5105
I recently had the pin hole for the right lift arm fail on a 2004 john deere 5105.
Has anyone else had this issue.
I am in the process of replacing the right axle housing with a used one.
Does anyone know the torque for the bolt in the end of the axle and the torque for the axle house retaining bolts.
   / axle housing failure #2
:welcome: to TBN
I do not have the service tech manual, but suspect your Deere dealer can bring that up on the computer with that torque information.
jdparts appears to show a spring pin (2 on each pin [part no. R139197] ) that keeps the nuts on each end from coming unthreaded. Does that fit with what you have?
Any idea what may have caused that casting failure?
   / axle housing failure #3
What were you hooked up to when it let loose?
   / axle housing failure #4
I have a PDF of the technical manual for your tractor, if wanted, shoot me your email.
Joe
2021 Deere 333G (A53317)
2021 Deere 333G...
2008 Ford E-350 Passenger Van (A55852)
2008 Ford E-350...
UNUSED FUTURE ELECTRIC BICYCLE (A57193)
UNUSED FUTURE...
2005 Ford F-150 Pickup Truck (A54814)
2005 Ford F-150...
2009 Lexus RX 350 SUV (A53424)
2009 Lexus RX 350...
2017 Mack GU713 Granite Tri-Axle Dump Truck (A51692)
2017 Mack GU713...
