Oil & Fuel Axle fluid
/ Axle fluid #1
pilot-werx
Southern Maine
Stupid question of the day because the dealer is closed and my manual is at the shop.... Does the front axle use the same hy-gard low viscosity fluid as the rest of the tractor?
/ Axle fluid #2
The manual for my JD 790 states to use John Deere GL-5, SAE 80W90 in the MFWD front axle. Don't know if your 4210 would be the same, but I doubt it would use a different type of fluid??? Maybe another can check their manual and say for sure.
/ Axle fluid #4
My 4210 uses Hy-Gard low vis in the front axle - same as the rest of the unit.
/ Axle fluid #6
From manual for your 4210
Add approximately 4.5 L (4.7 qt) of John Deere Low Viscosity HY-GARD (J20D) or HY-GARD (J20C) or equivalent into dipstick filler opening.
KUBOTA BX2380 TRACTOR (A64280)
KUBOTA BX2380...
(5) 2" X 20' STEEL PIPE (A64281)
(5) 2" X 20' STEEL...
Coleman Sky Lodge Instant Screen House (A62613)
Coleman Sky Lodge...
2022 Weber CR 5-II HD Reversible Plate Compactor (A61572)
2022 Weber CR 5-II...
Muck-Truck Wheelbarrow (A61567)
Muck-Truck...
2021 Wacker Neuson G25 Quiet Power 20kW Towable Generator (A61572)
2021 Wacker Neuson...
