Auxiliary Light Project
/ Auxiliary Light Project
Mackattack,
At idle there is a small amount of vibration which goes away as I throttle up. The only other movement I get is as the tractor bounces around.
I have to honestly say, that I have yet to actually use the tractor at night to need the lights, to see if bugs will be a concern.
OK, now your all probably wondering. If he has never used the lights, why did he install them. /forums/images/graemlins/confused.gif
It's a guy thing !! /forums/images/graemlins/grin.gif
Actually, at the present time, it was more important to me to have the flashing hazard ligts for safty while road traveling and for road side work.
/ Auxiliary Light Project #62
Mark I think the only reason that you are getting any vibration in the canopy & lights is the fact that the removable pin in the ROPS allows a little slop factor in the folding hinge arrangement. I noticed on my canopy the very same vibes the first week that I had my TC-40D. Because my rig is housed in a pole barn with 12 foot ceilings and 10 foot doors I removed the pins and inserted 5/8 inch grade 8 bolts & locknut's making my ROPS stationary. The vibration and noise that was originally there is now gone.
Now before the ROPS police chime in here let me state that I drilled no holes in my ROPS, and made no permanent changes to it. I can remove the bolts and locknut's, reinsert the pin & keeper at a later date if I choose to do so. /forums/images/graemlins/wink.gif
Mike,
Knowing the ROPS hinge's were going to be a minor problem and that I will never fold mine down. The very first thing I did was to remove the factory pins, inserted a small rubber wedge on each side and then securely bolted mine.
The vibrating I am getting is just there at idle, I dn't suspect that anything I do will get rid of it.
/ Auxiliary Light Project #64
Mark if you have already eliminated the ROPS lock pin, then the only difference that I might suspect between our two tractors that might be the difference is the 3 vs 4 cylinder engine. I thought possibly I might help with that idle vibe, sorry. /forums/images/graemlins/frown.gif
/ Auxiliary Light Project #65
Mark
What type and size tractor do you own?
/ Auxiliary Light Project #66
Hi Point. Mark has a New Holland TC35D w/ 16LA FEL.
I see that you are a new member here at TBN so I'll let you in on a shared secret. /forums/images/graemlins/smile.gif If you click on a members name in the left column and that member has filled in his bio you can retrieve a bit of information on their tractor as well as other useful info.
BTW since I let you in on this secret the next time that you help a new member it is now up to you to share this information with him. /forums/images/graemlins/grin.gif
I see that you didn't fill yours in yet so you may want to take a minute when you can to do that. /forums/images/graemlins/wink.gif
2010 Toyota 7FDKU40 7,350lb. Straight Mast Diesel Forklift (A60460)
2010 Toyota...
2012 FORD F450 XL SUPER DUTY TRUCK (A59823)
2012 FORD F450 XL...
2009 Honda Civic Sedan (A59231)
2009 Honda Civic...
JLG 660SJ (A58214)
JLG 660SJ (A58214)
2018 CATERPILLAR 336F L (A58214)
2018 CATERPILLAR...
2010 Ford F550 Bucket Truck with Altec AT37G Boom (A56435)
2010 Ford F550...
