Automobile (Firebird 400) Thermostat
   / Automobile (Firebird 400) Thermostat
The most worrisome thing you said was that it had this overheating problem when he bought it.
Late to reply, been out of town.
He bought if off his (now former) son in law. So someone (not me) knows more of the history.
None the less... lots of good ideas. When it warms up, I'm going to ask him about the both of us taking a look at it.
It would be a shame to see it sit there and rot, especially since it's got a rag-top.
   / Automobile (Firebird 400) Thermostat #22
Wife's cousin next door has a Firebird convertible. Not sure of the year... I'm guessing anywhere from 1969-1971. Has a 400 engine per emblem on the hood.
He doesn't drive it as he says it has an over-heating problem and has since he obtained it.
"Have you checked/replaced the pump?" Yep
"Have you checked/replaced the thermostat?" Yep
"Have you had the radiator looked at?" Yep, it's either new or cleaned/reinstalled
Says all the above were replaced and it still over-heats. He then went on to say (if I recall correctly) that the prior owner removed the stock fan blades and replaced them with an electric fan. So now, it's either on full time or (I suppose) not working or, working intermittently.
That said, I'm not 100% sure how accurate the fan part is. I never looked at the fan.
My primary question is, testing the thermostat. Are they stamped with what temp they open? I recall there is a range they can operate.... if not stamped on unit, how can one ascertain what it's rated at?
If it is this electric fan (I have NO experience with them) what is it tied to temp wise, to tell it when to kick in/out?
I'm certainly not a certified mechanic but, if I am not a certified mechanic.... then his rating would be that he's not a certified observer lol. What I mean to say there is my background is a LOT more mechcnially inclined than his... heck, I gave him a strobe timing light and a tach/Dwell meter because I'll never likely need them again. He said he had no clue how to use either one.
So, I'd like to help him. I didn't know about it having an electric fan. Seems to me the easy answer is to just go back to the fan with belt....
No real question.... just trying to see with the above, what other thoughts might be on where to look for the issue. The car is just sitting under a tarp... unused.... and I'm of the belief that cars do not like to be unused.
Take the thermostat out and take a short drive....if it doesn't over heat replace the thermostat and move to the next ...I myself would look at the electric fan set up ,old GM's need lots of air to cool em off...
   / Automobile (Firebird 400) Thermostat #23
Just take thermostat out and see if it still gets hot. Some engines you can't plug off a heater hose, it must be in a loop to circulate. Will get too hot in a jiffy. So check the heater hoses.
   / Automobile (Firebird 400) Thermostat #24
I understand. Let us know what you find out. I'd use the K.I.S.S. principle.
10,000 PSI AIR HYDRAULIC PUMP (A58214)
10,000 PSI AIR...
John Deere 855DXUV Gator (A57148)
John Deere 855DXUV...
Vermeer 605 XL Round Baler (A59814)
Vermeer 605 XL...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
2016 JOHN DEERE 135G (A58214)
2016 JOHN DEERE...
Hays LT1 Tender (A56438)
Hays LT1 Tender...
