Auto Throttle Control
   / Auto Throttle Control #1
Kubota 2350
Platinum Member
Michigan, In The Thumb
2016 JD 3046R Cab ...................... Mower: 2016 Scag Tiger Cat II ZTM
Anyone use the auto throttle control on the Ehydro, tried it while plowing snow yesterday and not sure if I like it or not.
What do you guy's do?
Anyone have a JD tractor with auto throttle?
If so do ya ever use it?
   / Auto Throttle Control #3
I had a Kubota with auto throttle. I didn’t like it. I prefer to adjust the throttle manually. My biggest complaint with it was it pretty much kept the tractor at 2700 rpm.
That's why I was asking, seems to really rev the engine when you press the peddle.
I usually run the engine at 1800 to 2000 RPM while using the tractor.
   / Auto Throttle Control #5
Another problem is it doesn’t fit how a HST is supposed to be driven. When the going gets tough you need more throttle and less pedal. Not less throttle and less pedal.
   / Auto Throttle Control #6
I use auto-throttle when pushing heavy snow;I plow my woods road about 1/2 mile long with an 8ft.front FEL mounted plow.The way I under-stand it;it up's the throttle and lowers the gear ratio in the HST.Seems to work well,never stall the tractor when using it.
   / Auto Throttle Control #7
The auto speed setup up on the TYM tries to maintain engine rpm by slowing the wheel speed, I use it when the cruise control is set. Problem I have is it takes to long for wheel speed to return. It's most noticeable during heavy grass cutting, therefore I only use it when the grass is beening maintained regularly, unless I know of a bad spot that may slow the unit.
2013 Polaris Ranger 500EFI (A52384)
2013 Polaris...
2018 Bobcat T590 (A50123)
2018 Bobcat T590...
City of Buckhannon Onan 200 Set Stand By Generator (A52384)
City of Buckhannon...
2003 Ford E-350 Cargo Van (A51692)
2003 Ford E-350...
2022 Club Car Tempo Cart (A51694)
2022 Club Car...
1985 International 1754 Material Spreader Dump Truck (A51691)
1985 International...
