Auto Engine RPM
/ Auto Engine RPM #1
chesternator
RK37 HC Hydrostatic Cab
On the dash is shows a min RPM and a picture of the auto function. Is this to mean you should operate at that min before engaging auto function?
/ Auto Engine RPM #2
Where are you seeing the minimum rpm? There's nothing in the manual linking rpm's with auto throttle that I can find. I pretty well use the auto throttle all the time except when using an attachment using the PTO function. The only thing I can see dealing with rpm min/max is the PTO rpm range on the tachometer.
/ Auto Engine RPM
It should be no surprise that its not in the manual.
Dead center on my tach (rk37) it says min with a picture which is the same picture that is on the auto throttle button.
I assume this either means operate at this min if using auto throttle or auto throttle will advance to this rpm as a minimum
/ Auto Engine RPM #4
If it's the same thing as the center of the tach on the RK55 (says n/min under an engine symbol) I think it's just a label for the gauge. Don't think it has anything to do with the auto throttle.
2025 60 Gallon Poly Diesel Tank w/ 12v Pump, nose, Nozzle and Pump (A64557)
2025 60 Gallon...
Case 580N (A64911)
Case 580N (A64911)
TAG 48" QUICK ATTACH EXCAVATOR BUCKET (A65053)
TAG 48" QUICK...
AMERICAN FORCE & FOUNDRY 10 TON AIR JACK (A67714)
AMERICAN FORCE &...
2018 GMC Sierra 2500HD 4x4 Pickup Truck (A66736)
2018 GMC Sierra...
2018 Chevrolet Tahoe SUV (A66738)
2018 Chevrolet...
