Auger storage rack?
/ Auger storage rack? #1
countrybumpkin
Elite Member
Kioti, kubota
AnyOne built there own rack and storage system for a hydraulic SSQA auger drive and bits? Only thing I've come across is "Auger Rack" which is a really nice design, just curios if anyone has come up with anything different.
/ Auger storage rack? #2
We just had ours on racks with lengths of pipe to set them over so they pointed up. Of course, they were stored outside as we had 2 ss augers and 5 two man Groundhogs, so there were quite a few auger bits around. Storing them that way they didn't fill up with water and it was easy to see if any needed teeth replaced, or other repairs. The last probably isn't important unless you have crews that are, shall we say, lax about reporting problems.
Thanks, I'm looking to keep the augers up right, so I can change out the augers with out having to Handle a 150 lbs auger alone. :) I'm probably going to end up building something very similar to the pic I guess, I like the idea of being able to move the whole setup around or set on a trailer or in a truck if I need to transport it.
/ Auger storage rack? #4
We only have 2 augers. We store the spare on the post hold digger stand. Both the top latch for the auger and the top for the digger rack are gravity fed for ease of operation. The tongue to move the stand around in the barn will slide up into the lower square tube for storage or for hooking up to the tractor.
Finally got a stand built , think it will work ok.
2016 FORD F650 ROLLBACK (A59909)
2016 FORD F650...
2023 Stearling Trailer (A60352)
2023 Stearling...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Bucket Truck (A60352)
2018 Freightliner...
UNUSED WOLVERINE 8' FORK EXTENSIONS (A62131)
UNUSED WOLVERINE...
Kubota KX080 Mini Excavator (A64047)
Kubota KX080 Mini...
CORE CUT CC1200XL WALK-BEHIND SAW (A62129)
CORE CUT CC1200XL...
