Auger Stand
/ Auger Stand #1
jacric2005
John Deere 870
There are some good YouTube videos on making a stand for your auger attachment. What is not provided is a way to more easily change to a different size auger - like 6" to 8" for example. Any ideas?
/ Auger Stand #2
I have a 12 inch auger, but for some reason I thought it was a good idea to get a 6 inch auger. There are two bolts that hold it on the gear shaft. I removed them and the auger slide right off. The smaller one slid on easily and the bolts went back on. I did it behind my tractor and it was a quick swap.
I hated the 6 inch auger and put the 12 inch back on a week later. I've never done it again.
/ Auger Stand
I'm hoping with a stand I may use it more.
/ Auger Stand #4
I too have the 12 and 6 inch bits. I use the 6 for posts and the 12 for plants/trees. I interchange them as the need arises and like Eddie mentions above I lift the auger until its about 5" off the ground. Loosen 1 bolt and let it slide out. Usually because I have been somewhat negligent in between uses I may have to sand off some surface rust so it will go back in the hole.
On a similar note, I had my BIL make me an attachment that bolts into the auger driver and I can now put in anchors. I have done this multiple times with the vineyard. Worked like a champ.
/ Auger Stand #5
The last time I installed the bit in the auger I found it easier to stand up the bit and align the auger drive pin and set it down that way. I suppose it depends on your ability to manhandle the bit. With one hand it's difficult to use jedi mind tricks to either levitate the bit so I can install the pin, or vice versa. So, the stand-up-the-bit move was easier for me.
The way I stood up the bit was just leaned it against the firewood pile. But it did bring about the idea to build a stand, maybe similar to a floor rifle rack. It doesn't have to be giant nor cumbersome.
/ Auger Stand #6
How do you guys store an Auger to make hooking and unhooking a one man job??
Pictures, Please!
/ Auger Stand #7
I built a frame and hang it from a chain and turnbuckle. This allows me to move it around when hooking it up to my tractor. I rarely use the turnbuckle for installing it, but I will tighten it up when taking the auger off of the tractor.
/ Auger Stand #8
how about drilling the auger in the ground to store it?
/ Auger Stand #9
Pictures, Please!
I hung mine from a tree branch at appropriate height with an adjustable strap til we built the pole barn. Now hangs from one of the 6x6 edge support poles.
/ Auger Stand #10
I thought about burying a piece of 16” pipe on gravel for drainage, so far hasn’t gone beyond that.
Hanging it seems better, next to disassembled for storage.
12FT X 20FT STEEL CARPORT (A58214)
12FT X 20FT STEEL...
INGERSOLL RAND G25 GENERATOR (A60736)
INGERSOLL RAND G25...
2022 John Deere 3025E (A60462)
2022 John Deere...
2025 MACK GRANITE GR64F DUMP TRUCK (A59823)
2025 MACK GRANITE...
2005 Big Tex 14TL (A60462)
2005 Big Tex 14TL...
Giyi 12" Excavator Bucket (A60463)
Giyi 12" Excavator...
