Auger Sizes
   / Auger Sizes #31
More on this -- I see I can buy carbide masonry bits around 40" long and 1.5" diameter for around $270. I'd have to make some kind of adapter if I wanted them on the tractor auger, as they have special splined shanks to fit a rotary hammer tool. Not sure I could handle them in a rotary hammer drill by hand, especially pulling back out.
   / Auger Sizes #32
I have a pile of augers that are 5 long and around 3 in diameter. The have 1-5/8 hexagonal connections on the ends.
Good bits for them are around $60 each and the auger sections are around $200 each. You would need an adapter made to fit them on a tractor auger. I get them at Mobile drill.
The bits you want are the two prong mining bits.
   / Auger Sizes #33
I have a BX2660 so same engine and PTO size as original poster . I went with 9 inch auger and in clay have got that badly stuck and the tractor overwhelmed. Large pipe wrench and pipe on handle to reverse it out. I hate to think what a bigger auger would be like . Keep in mind that even if your post size is tight for a 9 inch …..you can have more wiggle room to get them vertical by moving forward and back with tractor while auger is in ground to make upper part of hole larger.
   / Auger Sizes #34
Does anybody know where to get an auger smaller than 6"?
My soil is often so hard I can't even get the tip started - I mean the casting that looks like the end of a wood screw. I have round river gravel cemented together by clay. Many years ago I did a painfully big project with a 4 handle handheld auger and 3 of us, and we were actually using a masonry bit to drill pilot holes to get it started.
I'd like to find a 2" or so drill bit long enough to penetrate a couple feet into the ground. A masonry bit might work, or perhaps a drill bit intended for metal.
Another possibility would be more weight on the assembly. I haven't had a convenient point for hanging weight so perhaps that what I should try next.
Here is one for 30 bucks.
https://www.amazon.com/AuSable-Bran...nt=&hvlocphy=&hvtargid=pla-640958895754&psc=1
   / Auger Sizes #35
Wow. Looking through the products at https://mobiledrill.net/wp-content/uploads/2019/05/CFA-Pages.pdf now. Seriously impressive. Of course it should have occurred to me, people drill through all kinds of rock and wicked soil. It's expensive but I kind of want to go for it just to mess with augers this serious.
   / Auger Sizes #36
   / Auger Sizes #37
2017 Ford Explorer AWD SUV (A56859)
2017 Ford Explorer...
1998 Homemade S/A 12x6.5ft Trailer (A56859)
1998 Homemade S/A...
17101 (A55851)
17101 (A55851)
2013 Case 580 Super N 4x4 Extendahoe Loader Backhoe (A55973)
2013 Case 580...
2016 SERCO 8500 KNUCKLEBOOM LOADER (A58018)
2016 SERCO 8500...
2019 Freightliner Derrick Digger Truck (A55973)
2019 Freightliner...
