Auger Sizes
   / Auger Sizes
I will disagree. 9" & 12" are so close to each other I wouldn't 't buy both unless you are planning on a ton of digging or just have excess money to spend. If you plan on using something larger than a 4x4 then get a 12" but if not get a 9". I have a 9" and 18". The 9" has worked for the hundreds of fence post holes I have dug and the only time I have used the 18" on fencing was for setting some 6.5" pipe for an entryway. Other times it just gets used for setting sono tube footings, I-beams, planting trees, etc.
Don't misunderstand me 9" and 12" have their place and if you were doing a ton of fencing with a lot of small and larger fence posts then buying both might make sense but from what I gathered from your post the wasn't the case.
Good point, luckily I haven't ordered anything yet. Do you think 20hp PTO is capable of running a 18" auger though? That was my concern....
   / Auger Sizes #22
I don't know. I run mine on a 100hp skid steer with a hydraulic auger. 20HP is probably on the weak side depending on your soil. With an extension I have dug 8' deep holes with my 18" auger.
I wasn't necessarily recommending an 18" for you, I was just saying there isn't a lot of difference between a 9" & 12" for infrequent use. I wouldn't want to dig 500 12" holes for 2-3/8" pipe fence posts but if you only had a few to do it will work fine. I would rather spend my implement budget on other goodies than both a 9 & 12 unless you had a specific need.
   / Auger Sizes #23
I was just going to post a question: "Will a 6" Auger work for 4x4 Posts ?
Assuming the surrounding material is solid !
Also, I assume a 6" Auger will actually end up cutting a larger hole than 6" !
A second question: "If... the 6" Auger cuts a larger hole than 6", can we also assume a 6x6 Post might work with this sized Auger ?
Reading all of these "postings", is there an accepted standard for the size of the hole vs the post size !
My first Auger will be the 6", seems like most things I do should work with it !
   / Auger Sizes #24
Hey folks,
Planning to buy a post hole digger in the next few weeks :)
What size augers are worth buying with the implement? It will just be used for lifestyle property on a Kubota B26, so nothing too extreme or high powered.
I also figures the 'hydraulic assist' post hole digger might not be worth the extra $ in this case as I only have a small tractor.
Options are: 6 inch, 9 inch, 12 inch and 18 inch.
Also considering getting a few spare blades / tips for the augers.
Cheers! :)
I bought a 24" diameter auger for my 25 hp CUT so I could plant several trees.
I learned to attach a hand winch to the ROPS to get the auger out of the ground if I dug too deep.
Regards,
Yooper Dave
   / Auger Sizes #26
Regards,
Yooper Dave
Yikes!
I guess it works.
Until it doesn’t.
Man, I’d be very careful you don’t torque those ROPS too much.
I’d imagine a stuck auger could win that battle on some days.
   / Auger Sizes #27
Regards,
Yooper Dave
I need to use a 24" auger if I avoid hiring a backhoe to dig some piers for a cabin I'm building. Obviously the auger could be a less messy hole too.
I can rent the 24" auger bit for $100 weekly and already own a PHD with a 12" bit.
The ground involved will have some "casual" rocks but no rock shelf present. The rocks that show up on the surface there are sandstone and sedimentary, having dropped in from a cliff maybe 100' above this bench in the woods and deposited when Fred Flintstone lived nearby.
My tractor is a Kioti DK35SE with nearly 40hp. IMO rocks may stop some holes, not all in the 9 I need to dig.
i gotta say I'm a bit nervous on that large of a auger! With the 12" I used a spud bar for leverage thus two people involved.
I'd like to hear others comment on the use of that tractor and a 24" auger bit? Me thinks a backhoe may make sense?
   / Auger Sizes #28
I run an 18" auger with a 50 hp tractor in clay soils. I do have to be careful I don't screw it into the ground because it is a b___h to get back out, but otherwise there's plenty of power and probably more than I need. Be sure it's in contact with the ground before you start to turn it of course. The 10 hp difference between your tractor and mine isn't that big of a deal (for 18" auger) - another 1/3 (6") is a lot, but for $100/ week I'd give it a try. If it doesn't work out, then go the backhoe route. BTW, 9 holes isn't that many and you should be able to dig them with a PHD in a day or two even with occasional rocks.
   / Auger Sizes #29
I have a 9" auger for 4x4 posts and I find that either I am not good at measuring or that sometimes the slight angle I get from the auger, the post won't sit centered that I need to have some wiggle room for the posts. I think I am going to go with a 12" auger inthe near future.
   / Auger Sizes #30
Does anybody know where to get an auger smaller than 6"?
My soil is often so hard I can't even get the tip started - I mean the casting that looks like the end of a wood screw. I have round river gravel cemented together by clay. Many years ago I did a painfully big project with a 4 handle handheld auger and 3 of us, and we were actually using a masonry bit to drill pilot holes to get it started.
I'd like to find a 2" or so drill bit long enough to penetrate a couple feet into the ground. A masonry bit might work, or perhaps a drill bit intended for metal.
Another possibility would be more weight on the assembly. I haven't had a convenient point for hanging weight so perhaps that what I should try next.
NEW Skid Steer Attachment Plate (A59000)
NEW Skid Steer...
2004 Dodge Ram 1500 Crew Cab Pickup Truck (A56858)
2004 Dodge Ram...
2017 Kawasaki Mule 4010 4x4 Rescue Utility Cart (A56857)
2017 Kawasaki Mule...
2015 Hoist P360 36,000lb Diesel Forklift (A55973)
2015 Hoist P360...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2012 Ford F-550 Knapheide Service Truck with Liftgate (A56858)
2012 Ford F-550...
