ATV/UTV Pictures!
/ ATV/UTV Pictures! #321
Never tried uploading a picture but here goes.
Anyway this is a true working UTV
/ ATV/UTV Pictures! #323
What's that mounted on the front?
Roy, not sure if I'd answer your question or not. (just back checking in on this thread) It's like an SSQA of sorts, hydraulic connections to a movable arm. I have no attachments for it (they're gawd-awful expensive, and, that's what my tractors are for!). I still, however, have found uses for it. Such as I'd posted back in July:
/ ATV/UTV Pictures! #324
working Pictures!
Taken today while working and retrieving a 6x6 for another project. We've lost most of our snow here which is OK with us since we've got work remaining to do in the feild. The water in the photo is cascading over nonesuch shale, which is 1.1 billion years old.
/ ATV/UTV Pictures! #325
more ATV/UTV working pictures!
Taken today. Limited snow here so we just went out to test things..
/ ATV/UTV Pictures! #329
6 years old and still used every day. Tires are getting bald, and I want a solid windshield, but otherwise, it's been a great machine!!!!
/ ATV/UTV Pictures! #331
We've been receiving snow here and got a few photos while out working with it. Hope you like them.
/ ATV/UTV Pictures!
Eddie,
That is a great photo! That right there (with the wood in the back and the splitter in tow) is the main reason I'd love a UTV.
/ ATV/UTV Pictures! #333
ATV/UTV snow photos!
Here is some recent work photos.
/ ATV/UTV Pictures! #334
Hereエs my 2001 Kawasaki Mule. 2510 diesel
/ ATV/UTV Pictures! #335
Got the led light bar and rear lights done today. Switches came today but were the wrong ones, factory kubota ones will be in tomorrow. Ready to see better at night.
Brett
/ ATV/UTV Pictures! #336
Brett
Brett, I installed mine in March 2016 and they really make a big difference at night. Mine are combination spot / flood lights. Looks like decided to go big ..... or go home!
Rangers have extra switch holes in dash, so just removed the blanks and popped in switches. I found switches on either eBay or Amazon that were labeled and have internal lamps so you can find them in the dark. I’ll see what I ordered and let you know where I got them.
I also installed a Steibel Compact air horn at same time. Horn and lights are wired to switches and horn push button thru relays. My Ranger has both switched and non-switched Power blocks behind dash and a cross member to mount the relays.
I’ll take pictures of the switches and horn button tomorrow.
I ordered the black air horn.
Amazon.com: Stebel 116919 - Nautilus Compact Mini Air Horn Black: Automotive
Seller contacted me that they were out of stock and asked if they could substitute the chrome model for no extra cost ....I accepted.
Amazon.com: Stebel 116939 - Nautilus Compact Mini Air Horn Chrome: Automotive
Really loud!
/ ATV/UTV Pictures! #337
Really loud!
Looks great. The kubota has a switch block on the roof panel. The dealer sent me 3 regular spade switches and I need the factory kubota ones that plug into the factory harness. I changed the mounts up on the front one and used all 4mounting points. Tomorrow night I should be able to try it out.
Those rangers are fast and fun!
Brett
/ ATV/UTV Pictures! #338
Brett
Yep, I’ve had mine up to 50 mph, on a smooth road.
It’s almost 10 years old and an XP700. Looking into trading it in on one of the 1000’s or a diesel.
BYW, mine is rarely that clean?
/ ATV/UTV Pictures! #339
Only time mine does 50 is on a trailer. Can’t believe it’s almost 10years old. Could pass for new in the pics. When you start shopping, if you can stand only going 25, the x1100c is hard to beat. Only takes a few mins For the heater to have the cab comfortable or the a/c freezing in the summer. Makes it nice to cruise around. My son and I went driving when it was snowing in tee shirts and shorts
Brett
/ ATV/UTV Pictures! #340
My dash. The “Roof Light” is front and “Work Light” is rear light. Red button is the air horn.
New/Unused landhonor 5 Gallon Vacuum Cleaner (A65583)
New/Unused...
Case Wheels for Combine/Firestone Tires w/ extra rings NO RESERVE (A63118)
Case Wheels for...
2018 MACK CXU (PINNACLE) (A65643)
2018 MACK CXU...
2019 Ford F-150 4x4 Ext. Cab Pickup Truck (A64556)
2019 Ford F-150...
2004 GMC Sierra Pickup Truck, VIN # 1GTHK23U24F110736 (A65563)
2004 GMC Sierra...
LOAD OUT AND SHIPPING (A65563)
LOAD OUT AND...
