ATV Spreader Battery
/ ATV Spreader Battery #1
lakngulf
Lake Martin Alabama
Kioti CK30
I bought a new 4Wheeler recently and looking to hook up my Moultrie seed spreader. On my old ATV I hardwired an extension cord receiving end to the battery, and spliced the other end to the cord from spreader. On this one I want to avoid hooking to the ATV battery, and just have a carry on to run the implements.
What type battery do I need? Will a battery made for a boat trolling motor run the spreader?
/ ATV Spreader Battery #2
A deep cycle battery is what you want but it will be more trouble than just using alligator clips to the ATV battery or hard wiring a power plug.
/ ATV Spreader Battery #4
get you a couple cheap packages of 4 plug trailer connectors (for rear of vehicle / bump pull trailers) and just use a couple plugs on them...
battery on atv to a plug male
alligator clips to a plug male
Moultrie seed spreader to a plug female
other equipment to a plug female
makes things a tad more universial i suppose. any 2 plug setup could work. i just choose trailer plugs, due to nearly every store has them. vs some sort of special 2 wire plugs. just be careful and don't plug them into an actual 4 plug on back of vehicle or you might blow a relay or fuse on the vehicle.
marine batteries for trolling motors are normally deep cycle batteries.
/ ATV Spreader Battery #5
I use the '2 wire' plugs also.
I have 2 pumps that I run extensively on my ATV. One is on my sprayer, and the other is on my foam marker. I probably spray 200 acres a year with my rig on athletic fields.
I run the sprayer with the ATV battery with some 2 wire plugs. I ran a wire from the battery to a switch on the handlebars and then back to the pump so that I can easily switch it off and on. This almost caused a disaster about 2 weeks ago, when the wires rubbed on the brake line over the years and shorted out and caused a fire between my handlebars. Luckily I was at my shop when this happened and one of my employees grabbed a water hose to put the fire out.
I run my foam marker with a separate battery on the front rack. I tried using small lawn mower batteries, but after a few days of spraying they won't hold a charge anymore. I now have a deep cell battery, which is much bigger and bulky, but it does hold a charge a lot longer.
2014 Ford F-150 4x4 Ext. Cab Pickup Truck (A64556)
2014 Ford F-150...
Farm Star 3Pt Bale Spear (A66408)
Farm Star 3Pt Bale...
2019 INTERNATIONAL LT625 6X4 T/A SLEEPER TRUCK TRACTOR (A59910)
2019 INTERNATIONAL...
2023 Takeuchi TL6R Compact Track Loader Skid Steer w Low Hours (A63689)
2023 Takeuchi TL6R...
2008 PRESVAC HYDRO BLASTER (A59914)
2008 PRESVAC HYDRO...
2023 JOHN DEERE 550P LGP CRAWLER DOZER (A65053)
2023 JOHN DEERE...
