Quick Hitches Attatchments sitting on the ground
   / Attatchments sitting on the ground #21
Pretty well everything goes on pallets. That way I can store them right in front of each other (I have limited flat storage space) move them to clear snow, set them just inside the garage to work on them (low door, tractor won't enter).
Someday I'll get the edges of the quanset hut cleaned out. Right now (and for the past ten years) I've just got a 10' path down the middle, full of skids with things like generators, logging winches, snow tires, skidoos, ontboard motors etc. Only takes ten minutes to pick up all the pallets and get to the far end. In winter my boat is back there, in summer its the skidoos....
Our weather might change from -30C to -5C (or +5C to +15C)over 24 hours. When it does anything made of steel gets covered with frost (condensation) A tarp just keeps it wet....
   / Attatchments sitting on the ground #22
Before I had adequate storage, I set a cheap piece of plastic down first and then a pallet and tool next.
Sometimes I would also cover with a tarp. If no tarp under the tool I would not cover it since it traps the moisture.
I have seen guys spray the tool with diesel fuel as well.
   / Attatchments sitting on the ground #23
As WoodLandFarms noted, as a "gentleman farmer" I keep everything I can under cover. When I farmed we kept our tractor under cover to have a dry seat for the daily use of farming or feeding livestock, but our equipment sat outside and on the ground. Our renters have a big no till planter and other equipment "stored" in one of our fields right now.
   / Attatchments sitting on the ground #24
Another vote for pallets. They are generally free and let you move equipment with forks or a pallet jack. They also keep the equipment out of the mud so they wont get frozen to the ground in winter.
2005 MACK TRI AXLE DUMP TRUCK (A52707)
2005 MACK TRI AXLE...
2023 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A55973)
2023 HarbinGer V3...
2012 NISSAN AWD Rogue (A56859)
2012 NISSAN AWD...
Kubota L3130 (A53317)
2013 Chevrolet Silverado 1500 Ext. Cab Pickup Truck (A55973)
2013 Chevrolet...
Enerpac RCS302 30-Ton Hydraulic Jack, 5" Tall (A59076)
Enerpac RCS302...
