attachment for cutting brush alongside trail?
   / attachment for cutting brush alongside trail? #11
</font><font color="blue" class="small">( I think its time to tell your wife you need an FEL.)</font>
At the same time, I would get a decent sprayer and spray the edges as needed to keep the brush and saplings from coming back.
   / attachment for cutting brush alongside trail? #12
</font><font color="blue" class="small">( We are also talking about 1 mile of trails, so doing it by "hand" with a string trimmer would take to long.)</font>
Me & 2 buddies are 'adopters' of a hiking trail in the White Mtns in New Hampshire. The trail is almost 3 miles long, up the side Mt Flume. Using the carbide-bladed trimmer we do the whole thing, 3 miles, in one day. It's thickets, brambles, blow-downs...the key is to get it early in the season before everything leafs out and takes off. If you can't find the tractor attachment you need/want before the growing season you might want to consider the manual labor...it's amazing how quickly the trail will become overgrown. Not to mention a malted beverage tastes sooooo good after a day doing that work!
Good luck - Norm
What type of trimmer are you using? Can you recommend a good model if I am going to go that route? It sounds like the trails you are clearing are similar to what I am facing. The actual trails I can cut with the tractor, its along the edges that I need to thin.
I had considerred a loader, but my neighbor told me if I try and run over the thorn bushes, they will more than likely puncture the R4's on my JD. Otherwise I was going to buy a loader, bash down the brush, and then run over it with the mower.
   / attachment for cutting brush alongside trail? #14
<font color="blue"> I had considerred a loader, but my neighbor told me if I try and run over the thorn bushes, they will more than likely puncture the R4's on my JD. </font>
Consider getting your front tires foam fillled. It is relatively cheap on a small tractor. Cost me $38 each for my Kubota BX fronts and $70 each for my B2910, to give you some idea of price.
Nothing beats not having to worry about front flats except having a loader!!!
Foam fill the front tires, forget about flats, and get the loader! That's what I would do... /forums/images/graemlins/blush.gif
(Not sure the loader is the answer to this one problem...but it sure is the answer to many others... /forums/images/graemlins/grin.gif )
   / attachment for cutting brush alongside trail? #15
I have a JD gas powered trimmer that I use their blade on, works a treat but it does get heavy after a couple of hours work. I also have a pole saw that extends up to 12 feet, works great for getting down some long low hanging branches and you can reach in under a thorn bush and cut it off, might not even have to get off the seat with it!
   / attachment for cutting brush alongside trail? #16
You're killing me, and probably the poster as well! Poor man doesn't have a 60 HP tractor but a 20, and you're showing him all these to-die-for options that he can't use. /forums/images/graemlins/grin.gif
Sure would be nice to have something for our smaller tractors like these you've posted, just smaller versions that wouldn't require a lot of hydraulic flow.
John
   / attachment for cutting brush alongside trail? #18
How about this brush cutter from Billy Goat?
link
Country Home products has a similar unit:
link 2
Edited long url
   / attachment for cutting brush alongside trail? #19
Dave,
You didn't say if your pole saw was manual or a "chainsaw on a stick" but I have a Stihl powered pole saw and it works great for pruning trails. Reaching into thorns is no problem and even though that little saw looks rinky-dink, it seems to cut bettter than my small conventional Stihl chain saw. Sometimes I grab it instead of the regular one, even on jobs that don't need the reach. Only problem is it gets heavier every year.
One additional point: Stihl makes a power head/pole that has interchangeable heads like a chainsaw, hedge trimmer, and others. The dealer said the hedgetrimmer will cut anything that will fit into its openings, which seemed to be about 1/2" from memory. That would really be faster than the chainsaw depending on the size of brush.
John
2014 INTERNATIONAL 7400 SBA 42 LUBE TRUCK (A51406)
2014 INTERNATIONAL...
Quick Attach 6' Snow Blade (A50515)
Quick Attach 6'...
1998 VOLVO A40 OFFROAD DUMP TRUCK (A51242)
1998 VOLVO A40...
Woods 3180 Batwing Mower (A50514)
Woods 3180 Batwing...
2018 INTERNATIONAL 4300 24FT NON CDL BOX TRUCK (A51222)
2018 INTERNATIONAL...
2013 INTERNATIONAL WORKSTAR 7600 SBA 6X4 DUMP TRK (A51406)
2013 INTERNATIONAL...
