Attaching tow chain
/ Attaching tow chain #1
KTD
NE PA
JD 4310 e-hydro
I'm very new at this tractor stuff.
If I'm attaching a tow chain to drag a log out of the woods should I attach it to the tractor drawbar, or should a get a bar that attaches between the draft arms? Where's the strength?
ktd
ktd
/ Attaching tow chain #3
Every thing I have read about my tractor says to pull from the drawbar only. There are several warnings in my operators manual about turning the tractor over if you pull from another point. But ---- there alot of sources here to get an attachment to move trailers from the 3pt.
/ Attaching tow chain #4
/ Attaching tow chain #5
Or you can use something like this. It's a bit pricey at 3K
Randy
/ Attaching tow chain #6
Randy
/ Attaching tow chain #7
The strongest thing to pull from is the drawbar. It is also the safest. If you use one of those 3ph hitch bars and pull from the side then all that load is acting to pull your 3ph to the side and your stabilizers are at risk of failure. That being said, pulling light stuff pretty straight I just chain off to my box blade.
I pull the log to where it needs to go, unhook the log and wind the chain around the boxblade and then back into the log with the back of the boxblade to shove it firmly into the stack. Then pull forward to get another.
/ Attaching tow chain #8
/ Attaching tow chain #9
The lower you can pull and still get the front of the log off the ground the better. Hooking the chain close to the drawbar helps, and there is some lifting action when you start forward. Here's a handy gadget for your drawbar.
/ Attaching tow chain #10
/ Attaching tow chain #11
I was going to explain my method of towing logs or rocks with my very small tractor however Slamfire has already questioned me on my procedure so I think I'll leave it lie.
If you are asking questions be on the safe side and tow only from the fixed draw bar! /forums/images/graemlins/grin.gif
Egon /forums/images/graemlins/grin.gif
/ Attaching tow chain #12
Thanks for all the replies and information.
The drawbar fastening to the tractor must be stronger than it appears.
A drawbar hook is already on my shopping list.
/ Attaching tow chain #15
Someday I'll post a picture of my bright idea for towin' logs. Spent around $50 on parts and labor. This equipment is guarenteed to lever your front wheels off the ground. /forums/images/graemlins/tongue.gif
Fortunately I lived long enough to try somethin different. /forums/images/graemlins/grin.gif
/ Attaching tow chain #16
1984 Cab Over K100 Big Cam 350 (A62613)
1984 Cab Over K100...
Denyo DCA-600SPK 500kW Sound-Attenuated Diesel Generator (A63689)
Denyo DCA-600SPK...
2024 GMC Yukon Denali 4x4 SUV (A61574)
2024 GMC Yukon...
New/Unused Landhonor Power Rake (A65583)
New/Unused...
2020 CATERPILLAR 316FL EXCAVTOR (A65053)
2020 CATERPILLAR...
ATTENTION PLEASE READ (A64127)
ATTENTION PLEASE...
