Snow Attaching Snow plow blade to 4 in 1 Bucket
   / Attaching Snow plow blade to 4 in 1 Bucket #1
oe2x
Hood River OR
Kubota L35
I have an L35 and 1/2 mile long driveway. It will need an occasional plowing. I would prefer not to use a back blade and instead attach a snow plow to the bucket.
I'm thinking with some basic fabrication this plow can be bolted onto the bucket.
Has anyone done this?
   / Attaching Snow plow blade to 4 in 1 Bucket #2
Do you have a quick attach (skid steer or other) on the FEL? Sounds like a good excuse to get one, then add pallet forks as well. Adapter plates are available for $100-$200 that you could weld to the plow frame. It would make for a quicker & easier install.
It's easy spending other's money:eek:
I have the standard mount on the FEL. Would it work if I got a couple of sleeves welded onto the plow that would fit on the sides of the bucket. A couple of bolts through each of the sleeves / sides of the bucket... ???
   / Attaching Snow plow blade to 4 in 1 Bucket #4
Most setups I've seen where the plow is attached to the bucket involve bolting thru the bottom of the bucket towards the back. The exception being the "snow pushers" you see in a parking lot that slip over the lip of the bucket & are chained in place.
In your case (4 in 1), the back of the bottom bucket isn't as strong as a regular bucket due to the hinged action, thus your idea to attach to the sides would be a sturdier mount.
I still say upgrade to the quick attach if you can spare the cash - you can retrofit your 4 in 1 bucket with one of the aforementioned plates. Your plow is going to hang waaaay out in front (which is tough if you've got tight quarters or undulating terrain).
FUEL CELL (A58214)
FUEL CELL (A58214)
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2013 Ford F-150...
NEW Wolverine 72in Skid Steer Tiller (A59000)
NEW Wolverine 72in...
2020 CATERPILLAR 289D3 SKID STEER (A52709)
2020 CATERPILLAR...
2017 VOLVO VNL TANDEM AXLE DAY CAB (A58018)
2017 VOLVO VNL...
Trailmobile Van Trailer (A56435)
Trailmobile Van...
