attaching MMM to B7500
   / attaching MMM to B7500 #1
spirit1217
Cranesville, PA
Kubota L3400
This is my first time trying to attach the MMM to my B7500 and I can't figure out how to lower the brackets that attach to the MMM. The only thing I saw that would hold them up was a clevis pin on both sides I removed both pins but when I try to lower them without the pins it still feels like there is something else holding them up in place. I have attached a picture of the bracket where I removed the pin from. Any advise would be greatly appreciated.
Mike
   / attaching MMM to B7500 #2
Your picture shows the gold bracket for holding the arms up when mower is removed. When MMM is installed use the pins to hold the gold bracket up out of the way.
Lowering 3PH should allow you to hook up mower arms to the mower.
   / attaching MMM to B7500 #3
If you don't have any weight on your 3-point they may be staying up even though you are putting the lever in lowering position. You may need to use your foot on the 3-points while pushing lever forward. I do this on my BX to lower it. You don't need to start it up to do it either.
   / attaching MMM to B7500 #4
Took a quick look in my 72" MMM manual. It has some good drawings of the linkage. Do you have a manual for your MMM?
   / attaching MMM to B7500 #5
Did you try opening the valve below the seat that controls the rate at which the deck lowers? I suppose that if that was closed enough the arms might not drop with only their own weight.
Jeff
Yes I do have the manual and I thought I was doing it correctly. I have taken a couple more pictures as you can see the rear arms are all the way down but the arms for the MMM are still in the up position. If there is anything you could think of. I am open for any suggestions as the grass is getting long.
Thanks
Mike
Another picture of the arms under the tractor with the rear arm all the way lowered.
   / attaching MMM to B7500 #8
do you have a height adustment knob for the MMM on the tractor. make sure it is not set to up or lock.
The only two things I am aware of is the lever to lower the 3-point and the knob that adjusted the speed of the 3-point. Whould there be something else?
   / attaching MMM to B7500 #10
Sprit, I think Surfran was right - - the arms will not lower without some weight to pull them down. I just re-installed my 60" MMM on my BX [my 1st time too]. It will take a bit of down pressure to get the arms down. Ordinarily, your 3ph implement/MMM are on to pull the arms down.
Good luck.
2013 JLG 8042 TELEHANDLER (A50854)
2013 JLG 8042...
IH Cub Lo-Boy 154 (A50514)
IH Cub Lo-Boy 154...
Bron V75-3 Pull-Behind Hydraulic Vibratory Utility Plow (A49461)
Bron V75-3...
2018 Toyota RAV4 Hybrid XLE AWD SUV (A50324)
2018 Toyota RAV4...
2000 John Deere 1860, 30ft Wide, Gandy Box, Wing Fold, 7.5in Spacing (A51039)
2000 John Deere...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2003 Big Tex 10PI...
