Attaching KA160 Blower SOLVED
/ Attaching KA160 Blower SOLVED #1
MountainBuck
TN
Ventrac 4500P; Kubota RTV-X1100C
Just bought the KA160 blower for my 4500 and was very pleased with the way it worked.
However, if I just disconnected it on the ground, it was very very low for the front forks to pick it back up again. If I put it on a pallet, it became too high.
So did some measuring and came up with this pad I made from simple 2x4's.
Thought it might be of interest to someone. Important dimensions are on the pics. Put it together with lag bolts and deck screws and whatever I had extra. The two balls on the top are doggie chew toys from Wally mart.
The two rubber balls keep the blower from falling off of the pad when attaching and un attaching. I put the blower on the pad first then marked where the balls should be placed.
I wanted the wheels on the unit to not touch anything so that it wouldn't "run" on me while trying to attach it.
/ Attaching KA160 Blower SOLVED #2
Not a bad idea.... I have a stump grinder and that may well be the way to get it to level up so you can move it around some...
So how is the blower???
Mark
This blower exceeded my expectations for performance.
I thought that I would operate it in "float" most of the time but actually I pick it up and adjust the height to control the effect of the high velocity air. If the unit is all the way down it will start to blow the gravel off my gravel drive.
There is no velocity adjustment other than engine speed so its either "on" or "off" but that doesn't seem to be an issue for me.
It seems more powerful than a larger gas powered walk-behind unit that I've used.
Adams Under Truck Conveyor (A63688)
Adams Under Truck...
2015 Chevrolet Traverse SUV (A61574)
2015 Chevrolet...
1999 Sterling L9513 Tri-Axle Roll Off Truck (A59230)
1999 Sterling...
2019 Merlo TF 42.7 (A60462)
2019 Merlo TF 42.7...
1986 INTERNATIONAL 1900 FLATBED TRUCK (A63291)
1986 INTERNATIONAL...
2023 CASE TV450B SKID STEER (A64279)
2023 CASE TV450B...
