Attaching bucket hooks to a Kubota MX5400 with L2236 bucket
   / Attaching bucket hooks to a Kubota MX5400 with L2236 bucket #11
For the weldors in the group, please remember that we sell 5/16" and 3/8" weldable grabs too, they are the only grade 70 ones that are forged here in the great ol' USA. We also sell other raw parts as well.
   / Attaching bucket hooks to a Kubota MX5400 with L2236 bucket #12
1st mod on my MX5200 was welding on bucket hooks. Bought em on Amazon.
That the best idea I’ve seen. I welded mine to the bucket
   / Attaching bucket hooks to a Kubota MX5400 with L2236 bucket #13
That looks like nice work. What do you do when the job nees ropes or straps instead of chains?
   / Attaching bucket hooks to a Kubota MX5400 with L2236 bucket #14
I have welded hooks in the same location. What I do is connect a short piece of chain to the two hooks, then attach some axle straps to the center of the chain. I can hook any strap to the D rings on the axle strap.
   / Attaching bucket hooks to a Kubota MX5400 with L2236 bucket #15
IDK? Use the forklift ;) I honestly don't use rope, chains are stronger and I have lots of them. The forklift back cage is pretty rope and strap friendly. An old guy with a bad back needs a forklift around.
Your needs may be different.
   / Attaching bucket hooks to a Kubota MX5400 with L2236 bucket #16
Agreed, and I've got some chain grab hooks with clevises for lifting & pulling. We use what fits the job. Sometimes chain, straps, or ropes. Being an old sailor, I probably use ropes more than most. So this last time I put some rope tie points onto the bucket as well. Much better for tying things in. Gotta say that after handling chains all day, handling rope is a pleasure.
   / Attaching bucket hooks to a Kubota MX5400 with L2236 bucket #17
I'm not sure how/where to attach these. It is a curved back bucket but has a plate mounted on top between the loader connections. How are others with this bucket adding bucket hooks like Ken's bolt ons?
   / Attaching bucket hooks to a Kubota MX5400 with L2236 bucket #18
That looks like nice work. What do you do when the job needs ropes or straps instead of chains?
I welded on safety hooks 6" from the end. This is where the factory hooks on the Massey 20C bucket are. I then welded in 3/8" grab hooks in line with the outer edge of the skid steer quick attach plate. The prior owner had welded on the center ring. This is a Gehl skidsteer bucket with a heavy boxed upper lip so its strong enough to handle the loads. Below is a photo of me prepping to weld the grab hooks on.
These are the safety hooks I use.
I wish I could have found weldon hooks like these. MF and JD used them, this is on a 410C. They are a combined loop and on the back have a nice hook.
   / Attaching bucket hooks to a Kubota MX5400 with L2236 bucket #19
Here is what I did on my MX5400 bucket. Used weld on hooks on top. Welded to plate then plate welded to bucket. Also drilled hole in center of cutting edge and fabbed a hook that can be mounted there. I also can mount a hitch ball there to very easily move trailers around.
   / Attaching bucket hooks to a Kubota MX5400 with L2236 bucket #20
I put hooks on the bucket too MX5200
(2) LITHONIA LIGHTING LUMINAIRE FITTING LIGHTS (A54756)
(2) LITHONIA...
2008 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A55745)
2008 DRAGON 150...
2012 GMC Acadia SUV (A55758)
2012 GMC Acadia...
2012 Big Tex 14ET-20BK 20ft T/A Flatbed Trailer (A55851)
2012 Big Tex...
2025 Greatbear14ft Bi-Parting Gate Deer Design (A55758)
2025 Greatbear14ft...
Giyi 59" Vibrating Roller (A53316)
Giyi 59" Vibrating...
