Grapple ATI Grapple
/ ATI Grapple #1
Vermonster
Fairfax, Vermont
NH TC29S
Does anyone have any experience with ATI's grapple attachment? Info on this thing is at <A target="_blank" HREF=http://www.pfvirtualfarmshow.com/new_products/1101a.asp>http://www.pfvirtualfarmshow.com/new_products/1101a.asp</A>
/ ATI Grapple #2
Michael
I looked into one for my 2910. Decided to make my own.
<A target="_blank" HREF=http://www.carverequipment.com/>Carver Equipment</A> carries the ATI grapple. The main concern for smaller compact tractors is the weight of the grapple may limit the amount that can be lifted with your FEL.
/ ATI Grapple #3
really nice work on your grapple. what size ram did you use and how are you controlling it?
/ ATI Grapple #4
Rob
I'm using a Lion 2" bore X 8" stoke cylinder. Pin center length is 18 1/4". I have a separate valve mounted under my loader valve. I have a set of hydraulic hoses that go to the front of Loader frame. There are a set of quick disconnects at this point. It allows me to remove Grapple by pulling 2 pins for cylinder, 2 pins for grapple arms and the quick disconnects. Frame stays on Loader bucket. The whole assembly weighs 170 lbs.
/ ATI Grapple #5
great I appreciate it, was thinking of building one for the kubota for capturing sewer and water pipes( those 20' lengths of 6" schedule 80 waterpipe are heavy).
/ ATI Grapple #6
Rob
Something similar to what I made should work great. I have a 30' Telephone Pole that I used to try mine out with. Ounce I learned the technique needed to pickup a 12" diameter pole. It sure beat using chains.
/ ATI Grapple #7
Ron - That's a very nice job! You'll find plenty of uses for it, I'm sure!
/ ATI Grapple #8
i've just bought 1 and still am working on plumbing it correctly .it will make moving logs and brush much easier
/ ATI Grapple #9
Did you buy it direct or through a dealer? How expensive are they? How good are the instructions? Pictures???? We love pictures... /forums/images/graemlins/smile.gif /forums/images/graemlins/smile.gif /forums/images/graemlins/smile.gif
/ ATI Grapple #10
junkman i got it from carver my local dealer didn't know they made small grapples .As for pictures opps!! deleted instead of downloaded from camera I will post new ones after next week.Price was about $750 with shipping and new control valve
2006 Ford F-150 Ext Cab Pickup Truck (A61573)
2006 Ford F-150...
F-250 Super Duty 4WD 6.2 (A63688)
F-250 Super Duty...
2012 Toro Z Master Professional 72in Zero Turn Mower (A61572)
2012 Toro Z Master...
2018 Takeuchi TL10V2 High Flow Compact Track Loader Skid Steer (A61572)
2018 Takeuchi...
(15) UNUSED 3 1/2' X 8' PLASTIC PROTECTION MATS (A64281)
(15) UNUSED 3 1/2'...
(2) BUCKET & BOX OF ASSORTED BOLTS & NAILS (A64281)
(2) BUCKET & BOX...
